주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 15 Ram (Memory Module) Replacement
필요한 것
    1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Make sure your laptop is powered off completely and is not connected to the charger.
      • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
      • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
      댓글 쓰기
    2. Dell Inspiron 15 Ram (Memory Module) Replacement: 2 단계, 이미지 1개 중 1개
      • Lift the battery at an angle using your fingertips and remove it from the laptop.
      • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
      댓글 쓰기
    1. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 3 단계, 이미지 3개 중 1개 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 3 단계, 이미지 3개 중 2개 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): 3 단계, 이미지 3개 중 3개
      • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
      • Using the plastic opening tool, pry the base cover from the base.
      • Slide the base cover towards you and remove it from the base. Put it aside.
      댓글 쓰기
    2. Dell Inspiron 15 Ram (Memory Module) Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 15 Ram (Memory Module) Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 15 Ram (Memory Module) Replacement: 4 단계, 이미지 3개 중 3개
      • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
      • Slide the memory module out of its slot and lift it out of the laptop base.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Edward Pacheco
회원 가입일: 03/06/16
852 평판
안내서 3개를 작성함
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G8
3 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 44
전체 시간: 7,411
