주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 1501 Display Replacement
필요한 것
  1. Dell Inspiron 1501 Display Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron 1501 Display Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron 1501 Display Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
    댓글 쓰기
  2. Dell Inspiron 1501 Display Replacement, Hinge Cover: 2 단계, 이미지 2개 중 1개 Dell Inspiron 1501 Display Replacement, Hinge Cover: 2 단계, 이미지 2개 중 2개
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
    댓글 쓰기
  3. Dell Inspiron 1501 Display Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Inspiron 1501 Display Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Inspiron 1501 Display Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
    댓글 쓰기
  4. Dell Inspiron 1501 Display Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 1501 Display Replacement: 4 단계, 이미지 2개 중 2개
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
    댓글 쓰기
  5. Dell Inspiron 1501 Display Replacement, Display: 5 단계, 이미지 2개 중 1개 Dell Inspiron 1501 Display Replacement, Display: 5 단계, 이미지 2개 중 2개
    • Close display and flip the laptop upside down.
    • Remove the two 8mm JIS #1 screws on the backplate that hold the display.
    댓글 쓰기
  6. Dell Inspiron 1501 Display Replacement: 6 단계, 이미지 1개 중 1개
    • From the back of the computer, remove the two screw covers.
    • Remove the two 8mm JIS #1 screws.
    댓글 쓰기
  7. Dell Inspiron 1501 Display Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron 1501 Display Replacement: 7 단계, 이미지 2개 중 2개
    • Turn the laptop over and open the display.
    • Remove the two 5mm JIS #1 screws on the display hinge.
    댓글 쓰기
  8. Dell Inspiron 1501 Display Replacement: 8 단계, 이미지 3개 중 1개 Dell Inspiron 1501 Display Replacement: 8 단계, 이미지 3개 중 2개 Dell Inspiron 1501 Display Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the antenna cables from the Mini-Card.
    • Be careful not to knock the standby switch when disconnecting the cables as it is easily broken.
    • Loosen the JIS #1 screw on the display cable.
    • Pull the pull-tab straight up to disconnect the display cable from the laptop.
    댓글 쓰기
  9. Dell Inspiron 1501 Display Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the display from the rest of the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Luc-Anthony Breneville
회원 가입일: 03/01/18
183 평판
안내서 1개를 작성함
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 UMass Dartmouth, Team S2-G4, Simcock Spring 2018 회원
UMASSD-SIMCOCK-S18S2G4
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 33
전체 시간: 1,325
