주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 1526 Memory Module Replacement
필요한 것
    1. Dell Inspiron 1526 Memory Module Replacement, Remove the Cover: 1 단계, 이미지 2개 중 1개 Dell Inspiron 1526 Memory Module Replacement, Remove the Cover: 1 단계, 이미지 2개 중 2개
      • Follow the procedures in Before You Begin.
      • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
      댓글 쓰기
    2. Dell Inspiron 1526 Memory Module Replacement, Popping up the Memory Module: 2 단계, 이미지 2개 중 1개 Dell Inspiron 1526 Memory Module Replacement, Popping up the Memory Module: 2 단계, 이미지 2개 중 2개
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      댓글 쓰기
    3. Dell Inspiron 1526 Memory Module Replacement, Remove the Module: 3 단계, 이미지 1개 중 1개
      • Remove the module from the connector.
      댓글 쓰기
    4. Dell Inspiron 1526 Memory Module Replacement, Align the Notch: 4 단계, 이미지 2개 중 1개 Dell Inspiron 1526 Memory Module Replacement, Align the Notch: 4 단계, 이미지 2개 중 2개
      • Align the notch in the module edge connector with the tab in the connector slot.
      댓글 쓰기
    5. Dell Inspiron 1526 Memory Module Replacement, Sliding the Module: 5 단계, 이미지 1개 중 1개
      • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
      댓글 쓰기
    6. Dell Inspiron 1526 Memory Module Replacement, Replace the Cover: 6 단계, 이미지 1개 중 1개
      • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
      • Replace the memory module cover.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
80,125 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 4,987개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 406
