주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 1545 Keyboard Replacement
필요한 것
  1. Dell Inspiron 1545 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
    댓글 쓰기
  2. Dell Inspiron 1545 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the release latch while simultaneously pulling backwards on the battery.
    댓글 쓰기
  3. Dell Inspiron 1545 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the battery out of the battery bay.
    댓글 쓰기
  4. Dell Inspiron 1545 Keyboard Replacement, Base Cover: 4 단계, 이미지 1개 중 1개
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
    댓글 쓰기
  5. Dell Inspiron 1545 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 1545 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully lift the base cover vertically away from the laptop.
    댓글 쓰기
  6. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: 6 단계, 이미지 1개 중 1개
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
    댓글 쓰기
  7. Dell Inspiron 1545 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Flip the laptop over to the front and open the display as far as possible.
    댓글 쓰기
  8. Dell Inspiron 1545 Keyboard Replacement: 8 단계, 이미지 3개 중 1개 Dell Inspiron 1545 Keyboard Replacement: 8 단계, 이미지 3개 중 2개 Dell Inspiron 1545 Keyboard Replacement: 8 단계, 이미지 3개 중 3개
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
    댓글 쓰기
  9. Dell Inspiron 1545 Keyboard Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
    댓글 쓰기
  10. Dell Inspiron 1545 Keyboard Replacement: 10 단계, 이미지 1개 중 1개
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
    댓글 쓰기
  11. Dell Inspiron 1545 Keyboard Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
    댓글 쓰기
  12. Dell Inspiron 1545 Keyboard Replacement: 12 단계, 이미지 1개 중 1개
    • Lift the keyboard up and away from the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nathan Lemay
회원 가입일: 04/16/14
3,160 평판
안내서 15개를 작성함
Cal Poly, Team 9-14, Regan Spring 2014 Cal Poly, Team 9-14, Regan Spring 2014 회원
CPSU-REGAN-S14S9G14
4 회원들
안내서 15개를 작성함
3가이드 댓글
Step 4 and 5 are not needed.
James Thrun - 답글 공유
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - 답글 공유
The connector latch is broken. What should I do?
Mjeed - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 55
전체 시간: 7,966
