주요 콘텐츠로 건너뛰기
Dell Inspiron 3501 Battery Replacement
필요한 것
  1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: 1 단계, 이미지 1/2 Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: 1 단계, 이미지 2/2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: 2 단계, 이미지 1/2 Dell Inspiron 3501 Battery Replacement, Unclip the front corners: 2 단계, 이미지 2/2
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: 3 단계, 이미지 1/2 Dell Inspiron 3501 Battery Replacement, Unclip the front edge: 3 단계, 이미지 2/2
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 3501 Battery Replacement, Remove the back cover: 4 단계, 이미지 1/3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: 4 단계, 이미지 2/3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: 5 단계, 이미지 1/2 Dell Inspiron 3501 Battery Replacement, Disconnect the battery: 5 단계, 이미지 2/2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: 6 단계, 이미지 1/2 Dell Inspiron 3501 Battery Replacement, Unfasten the battery: 6 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the three 3.3 mm-long screws securing the battery.
  7. Dell Inspiron 3501 Battery Replacement, Remove the battery: 7 단계, 이미지 1/3 Dell Inspiron 3501 Battery Replacement, Remove the battery: 7 단계, 이미지 2/3 Dell Inspiron 3501 Battery Replacement, Remove the battery: 7 단계, 이미지 3/3
    • Lift the battery straight out of its recess and remove it.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
127,767 평판
안내서 592개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 92
전체 시간: 1,381
