주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 3520 Optical Drive Replacement
필요한 것
  1. Dell Inspiron 3520 Optical Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Optical Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
    댓글 쓰기
  2. Dell Inspiron 3520 Optical Drive Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 3520 Optical Drive Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 3520 Optical Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
    댓글 쓰기
  3. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
    댓글 쓰기
  4. Dell Inspiron 3520 Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the keyboard forward towards the screen to release the bottom tabs.
    댓글 쓰기
  5. Dell Inspiron 3520 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
    댓글 쓰기
  6. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: 6 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: 6 단계, 이미지 2개 중 2개
    • Locate and remove the 4mm Phillips #00 mounting screw.
    댓글 쓰기
  7. Dell Inspiron 3520 Optical Drive Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Optical Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Push the optical drive from the inside a little bit to dislodge it.
    • Grab the drive with your hand from the outside and slide it free.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Ian
회원 가입일: 01/30/15
1,638 평판
안내서 5개를 작성함
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G2
3 회원들
안내서 5개를 작성함
1가이드 댓글
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 3,120
