주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 3520 Screen Replacement
필요한 것
  1. Dell Inspiron 3520 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
    댓글 쓰기
  2. Dell Inspiron 3520 Screen Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 3520 Screen Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 3520 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
    댓글 쓰기
  3. Dell Inspiron 3520 Screen Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Screen Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
    댓글 쓰기
  4. Dell Inspiron 3520 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the keyboard forward towards the screen to release the bottom tabs.
    댓글 쓰기
  5. Dell Inspiron 3520 Screen Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
    댓글 쓰기
  6. Dell Inspiron 3520 Screen Replacement, Screen: 6 단계, 이미지 3개 중 1개 Dell Inspiron 3520 Screen Replacement, Screen: 6 단계, 이미지 3개 중 2개 Dell Inspiron 3520 Screen Replacement, Screen: 6 단계, 이미지 3개 중 3개
    • Locate and remove the 14 (5mm) Phillips #00 screws from the bottom of the laptop.
    • Locate and remove the two 5mm Phillips #00 screws found under the keyboard.
    • Disconnect the two controlling wires with the blue pull tabs.
    댓글 쓰기
  7. Dell Inspiron 3520 Screen Replacement: 7 단계, 이미지 3개 중 1개 Dell Inspiron 3520 Screen Replacement: 7 단계, 이미지 3개 중 2개 Dell Inspiron 3520 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Using the spudger, carefully work your way around the edge of the upper shell.
    • Lift the upper shell away from the laptop.
    • Close the laptop and remove the casing over the hinge using the spudger.
    댓글 쓰기
  8. Dell Inspiron 3520 Screen Replacement: 8 단계, 이미지 3개 중 1개 Dell Inspiron 3520 Screen Replacement: 8 단계, 이미지 3개 중 2개 Dell Inspiron 3520 Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Gently pull the cable located near the fan free from its dock.
    • Just behind the optical drive locate the 4mm Phillps #00 mounting screw for the small circuit board and remove it.
    • The board should then pull free.
    • Take note of how the cables fit along the ridge for when it comes to reassembly.
    댓글 쓰기
  9. Dell Inspiron 3520 Screen Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron 3520 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Open the laptop and locate the two hinges.
    • Each hinge has two 5mm Phillips #00 screws that need to be removed.
    • With the screws removed the screen should pull free.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ian
회원 가입일: 01/30/15
1,638 평판
안내서 5개를 작성함
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G2
3 회원들
안내서 5개를 작성함
1가이드 댓글
These instructions are not for screen replacement
Ryan Zulu - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 68
전체 시간: 7,093
