주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 6000 Fan Replacement
필요한 것
  1. Dell Inspiron 6000 Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
    댓글 쓰기
  2. Dell Inspiron 6000 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
    댓글 쓰기
  3. Dell Inspiron 6000 Fan Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Inspiron 6000 Fan Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Inspiron 6000 Fan Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
    댓글 쓰기
  4. Dell Inspiron 6000 Fan Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 6000 Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Remove two 4 mm Philips #00 screws.
    댓글 쓰기
  5. Dell Inspiron 6000 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
    댓글 쓰기
  6. Dell Inspiron 6000 Fan Replacement: 6 단계, 이미지 3개 중 1개 Dell Inspiron 6000 Fan Replacement: 6 단계, 이미지 3개 중 2개 Dell Inspiron 6000 Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Gently pull the blue tab up until it comes away from computer.
    댓글 쓰기
  7. Dell Inspiron 6000 Fan Replacement, Fan: 7 단계, 이미지 1개 중 1개
    • Unscrew the 4 mm Phillips #00 screw.
    • The screw will remain attached to the cord when fully removed.
    댓글 쓰기
  8. Dell Inspiron 6000 Fan Replacement: 8 단계, 이미지 2개 중 1개 Dell Inspiron 6000 Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull the blue tab to separate the screen connection from the laptop.
    • Gently pull and disconnect the white and black cords from the power source.
    댓글 쓰기
  9. Dell Inspiron 6000 Fan Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron 6000 Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Remove four 4mm #00 Philips screws from the screen hinges.
    • Lift the screen away from the laptop.
    댓글 쓰기
  10. Dell Inspiron 6000 Fan Replacement: 10 단계, 이미지 2개 중 1개 Dell Inspiron 6000 Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Remove two 4 mm Philips #00 screws that connect top of laptop to base..
    댓글 쓰기
  11. Dell Inspiron 6000 Fan Replacement: 11 단계, 이미지 1개 중 1개
    • Flip laptop the over and remove thirteen 6mm Philips #00 screws.
    댓글 쓰기
  12. Dell Inspiron 6000 Fan Replacement: 12 단계, 이미지 2개 중 1개 Dell Inspiron 6000 Fan Replacement: 12 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool in between the back and front plates of the laptop
    댓글 쓰기
  13. Dell Inspiron 6000 Fan Replacement: 13 단계, 이미지 1개 중 1개
    댓글 쓰기
  14. Dell Inspiron 6000 Fan Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the fan power cord
    댓글 쓰기
  15. Dell Inspiron 6000 Fan Replacement: 15 단계, 이미지 2개 중 1개 Dell Inspiron 6000 Fan Replacement: 15 단계, 이미지 2개 중 2개
    • Using your hand, lift the fan from the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jacob DeWar
회원 가입일: 09/23/14
563 평판
안내서 3개를 작성함
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G1
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 23
전체 시간: 2,756
