주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 8600 Video Card Replacement
필요한 것
  1. Dell Inspiron 8600 Video Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
    댓글 쓰기
  2. Dell Inspiron 8600 Video Card Replacement, Hinge Cover: 2 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Video Card Replacement, Hinge Cover: 2 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Video Card Replacement, Hinge Cover: 2 단계, 이미지 3개 중 3개
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
    댓글 쓰기
  3. Dell Inspiron 8600 Video Card Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
    댓글 쓰기
  4. Dell Inspiron 8600 Video Card Replacement, Keyboard: 4 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Video Card Replacement, Keyboard: 4 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Video Card Replacement, Keyboard: 4 단계, 이미지 3개 중 3개
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
    댓글 쓰기
  5. Dell Inspiron 8600 Video Card Replacement, Video Card: 5 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Video Card Replacement, Video Card: 5 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Video Card Replacement, Video Card: 5 단계, 이미지 3개 중 3개
    • After removing the keyboard, locate and remove the labeled screws.
    • Gently lift the Video Card unit for replacing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brian Murphy
회원 가입일: 04/13/11
368 평판
안내서 4개를 작성함
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 회원
CPSU-GARNER-S11S18G22
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 37
전체 시간: 7,578
