주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 9300 Trackpad Replacement
필요한 것
  1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: 1 단계, 이미지 1개 중 1개
    • Remove the battery in to order avoid damaging internal components.
    댓글 쓰기
  2. Dell Inspiron 9300 Trackpad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    댓글 쓰기
  3. Dell Inspiron 9300 Trackpad Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • There is a notch on the right-hand side of the bezel for easiest removal.
    댓글 쓰기
  4. Dell Inspiron 9300 Trackpad Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 9300 Trackpad Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 9300 Trackpad Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward, away from the motherboard.
    댓글 쓰기
  5. Dell Inspiron 9300 Trackpad Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 9300 Trackpad Replacement: 5 단계, 이미지 2개 중 2개
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
    댓글 쓰기
  6. Dell Inspiron 9300 Trackpad Replacement: 6 단계, 이미지 2개 중 1개 Dell Inspiron 9300 Trackpad Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
    댓글 쓰기
  7. Dell Inspiron 9300 Trackpad Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron 9300 Trackpad Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
    댓글 쓰기
  8. Dell Inspiron 9300 Trackpad Replacement: 8 단계, 이미지 1개 중 1개
    • Pull up and away on the upper case to remove.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Steven Faulkner
회원 가입일: 09/26/16
214 평판
안내서 2개를 작성함
USF Tampa, Team 16-6, Eyestone Fall 2016 USF Tampa, Team 16-6, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S16G6
5 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 497
