주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron B130 Screen Replacement
필요한 것
  1. Dell Inspiron B130 Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Inspiron B130 Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Inspiron B130 Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
    댓글 쓰기
  2. Dell Inspiron B130 Screen Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron B130 Screen Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron B130 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
    댓글 쓰기
  3. Dell Inspiron B130 Screen Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron B130 Screen Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron B130 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
    댓글 쓰기
  4. Dell Inspiron B130 Screen Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Put down the computer and open up the screen.
    • There is a long piece of plastic underneath the screen that you will have to remove.
    댓글 쓰기
  5. Dell Inspiron B130 Screen Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron B130 Screen Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron B130 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • When you pry the plastic plate off, be careful and pry gently so you do not crack the plastic.
    • Insert the plastic opening tool into the little slot.
    • Lift up gently and remove the plastic cover.
    댓글 쓰기
  6. Dell Inspiron B130 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 4mm screws at the top of the keyboard.
    • The keyboard is now loose but don't pull it out just yet. It is still connected underneath. Be gentle when lifting keyboard so you do not damage this connection.
    댓글 쓰기
  7. Dell Inspiron B130 Screen Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron B130 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Lift keyboard up slightly and you will see the keyboard connection.
    • This black tab has to be lifted up to remove the keyboard.
    • Put your finger underneath the tab and pull back gently as indicated.
    • You can now remove the keyboard.
    댓글 쓰기
  8. Dell Inspiron B130 Screen Replacement, Screen: 8 단계, 이미지 2개 중 1개 Dell Inspiron B130 Screen Replacement, Screen: 8 단계, 이미지 2개 중 2개
    • Detach the blue display connector.
    댓글 쓰기
  9. Dell Inspiron B130 Screen Replacement: 9 단계, 이미지 2개 중 1개 Dell Inspiron B130 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Detach the connector by pulling the two ends straight apart.
    • Avoid twisting or pulling at an angle to prevent damage.
    댓글 쓰기
  10. Dell Inspiron B130 Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove two 6 mm screws.
    댓글 쓰기
  11. Dell Inspiron B130 Screen Replacement: 11 단계, 이미지 2개 중 1개 Dell Inspiron B130 Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Close the computer and flip it over so that the back is facing up.
    • Remove the two 6mm screws that are behind each of the screen's pivot points using a Phillips #1 screwdriver.
    • Open up the screen and now it can be lifted up and off of the computer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Patrick McNeil
회원 가입일: 10/19/16
955 평판
안내서 8개를 작성함
UMass Dartmouth, Team 1-8, Catania Fall 2016 UMass Dartmouth, Team 1-8, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G8
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 652
