주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron N5030 Keyboard Replacement
필요한 것
  1. Dell Inspiron N5030 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron N5030 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
    댓글 쓰기
  2. Dell Inspiron N5030 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron N5030 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
    댓글 쓰기
  3. Dell Inspiron N5030 Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
    댓글 쓰기
  4. Dell Inspiron N5030 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Flip over the laptop and open it so that the screen faces you.
    댓글 쓰기
  5. Dell Inspiron N5030 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
    댓글 쓰기
  6. Dell Inspiron N5030 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
    댓글 쓰기
  7. Dell Inspiron N5030 Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
    댓글 쓰기
  8. Dell Inspiron N5030 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
    댓글 쓰기
  9. Dell Inspiron N5030 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the top keyboard panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Gunnar Salazar
회원 가입일: 09/30/13
128 평판
안내서 1개를 작성함
Cal Poly, Team 10-59, Amido Spring 2014 Cal Poly, Team 10-59, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G59
4 회원들
안내서 5개를 작성함
2가이드 댓글
What if i broke the blue ribbons connection to the keyboard
oibrahimopeyemi - 답글 공유
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
https://www.youtube.com/watch?v=jWuGb9AA...
Agropecuaria El Sinu - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 34
전체 시간: 3,266
