주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron N5030 RAM Replacement
필요한 것
  1. Dell Inspiron N5030 RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron N5030 RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
    댓글 쓰기
  2. Dell Inspiron N5030 RAM Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron N5030 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
    댓글 쓰기
  3. Dell Inspiron N5030 RAM Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
    댓글 쓰기
  4. Dell Inspiron N5030 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Flip over the laptop and open it so that the screen faces you.
    댓글 쓰기
  5. Dell Inspiron N5030 RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
    댓글 쓰기
  6. Dell Inspiron N5030 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
    댓글 쓰기
  7. Dell Inspiron N5030 RAM Replacement: 7 단계, 이미지 1개 중 1개
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
    댓글 쓰기
  8. Dell Inspiron N5030 RAM Replacement: 8 단계, 이미지 1개 중 1개
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
    댓글 쓰기
  9. Dell Inspiron N5030 RAM Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the top keyboard panel.
    댓글 쓰기
  10. Dell Inspiron N5030 RAM Replacement, RAM: 10 단계, 이미지 1개 중 1개
    • Place your fingers on the two metal tabs on the edges of the RAM.
    • Push on the tabs in the opposite direction.
    • The top RAM board will pop up after you push on the metal tabs.
    댓글 쓰기
  11. Dell Inspiron N5030 RAM Replacement: 11 단계, 이미지 1개 중 1개
    • Pull the top RAM board out with your fingers.
    댓글 쓰기
  12. Dell Inspiron N5030 RAM Replacement: 12 단계, 이미지 3개 중 1개 Dell Inspiron N5030 RAM Replacement: 12 단계, 이미지 3개 중 2개 Dell Inspiron N5030 RAM Replacement: 12 단계, 이미지 3개 중 3개
    • Repeat the above RAM board steps for the second RAM board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Rodrigo Perez
회원 가입일: 04/23/14
230 평판
안내서 1개를 작성함
Cal Poly, Team 10-59, Amido Spring 2014 Cal Poly, Team 10-59, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G59
4 회원들
안내서 5개를 작성함
3가이드 댓글
Looking at the Dell service manual. You dont need to remove any screws, but only the keyboard, and if your careful you dont need to remove the ribbon cable. Its all in the service manual you can download free from Dell.
swestonj - 답글 공유
swestonj is incorrect. The manual clearly states that you must remove the screws:
Service Manual
Removing the Keyboard
1. Follow the instructions in Before You Begin.
2. Remove the battery (see Removing the Battery).
3. Remove the two screws that secure the keyboard to the computer base.
etc.
mike - 답글 공유
зависит от целей. озу можно поменять не разбирая всё. а вот пзу придется все разобрать. я так и не понял сьёмный тут проц или припаян. вроде есть защелка
артемий Александровна троицкий - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 35
전체 시간: 6,081
