주요 콘텐츠로 건너뛰기
Dell Latitude 7410 Battery Replacement
필요한 것
  1. Dell Latitude 7410 Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/1
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Dell Latitude 7410 Battery Replacement, Unfasten the back cover: 2 단계, 이미지 1/1
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
  3. Dell Latitude 7410 Battery Replacement, Insert an opening pick: 3 단계, 이미지 1/2 Dell Latitude 7410 Battery Replacement, Insert an opening pick: 3 단계, 이미지 2/2
    • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
  4. Dell Latitude 7410 Battery Replacement, Unclip the right edge: 4 단계, 이미지 1/2 Dell Latitude 7410 Battery Replacement, Unclip the right edge: 4 단계, 이미지 2/2
    • Slide your pick along the right edge to release the clips securing the back cover.
  5. Dell Latitude 7410 Battery Replacement, Unclip the left edge: 5 단계, 이미지 1/3 Dell Latitude 7410 Battery Replacement, Unclip the left edge: 5 단계, 이미지 2/3 Dell Latitude 7410 Battery Replacement, Unclip the left edge: 5 단계, 이미지 3/3
    • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
    • Slide your pick along the left edge to release the clips.
  6. Dell Latitude 7410 Battery Replacement, Unclip the back edge: 6 단계, 이미지 1/3 Dell Latitude 7410 Battery Replacement, Unclip the back edge: 6 단계, 이미지 2/3 Dell Latitude 7410 Battery Replacement, Unclip the back edge: 6 단계, 이미지 3/3
    • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
    • Slide your pick toward the left hinge until the second clip releases.
  7. Dell Latitude 7410 Battery Replacement, Unclip the front edge: 7 단계, 이미지 1/2 Dell Latitude 7410 Battery Replacement, Unclip the front edge: 7 단계, 이미지 2/2
    • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
    • Slide your pick toward the right edge until the front edge releases from the frame.
  8. Dell Latitude 7410 Battery Replacement, Remove the back cover: 8 단계, 이미지 1/2 Dell Latitude 7410 Battery Replacement, Remove the back cover: 8 단계, 이미지 2/2
    • Remove the back cover.
  9. Dell Latitude 7410 Battery Replacement, Disconnect the battery: 9 단계, 이미지 1/2 Dell Latitude 7410 Battery Replacement, Disconnect the battery: 9 단계, 이미지 2/2
    • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
  10. Dell Latitude 7410 Battery Replacement, Unfasten the battery: 10 단계, 이미지 1/1
    • Use your Phillips screwdriver to loosen the four captive screws securing the battery.
  11. Dell Latitude 7410 Battery Replacement, Remove the battery: 11 단계, 이미지 1/2 Dell Latitude 7410 Battery Replacement, Remove the battery: 11 단계, 이미지 2/2
    • Remove the battery.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Clay Eickemeyer
회원 가입일: 09/19/22
68,385 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
137 회원들
안내서 17,632개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 85
전체 시간: 624
