주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude D620 CD Drive Replacement
필요한 것
  1. Dell Latitude D620 CD Drive Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    댓글 쓰기
  2. Dell Latitude D620 CD Drive Replacement: 2 단계, 이미지 3개 중 1개 Dell Latitude D620 CD Drive Replacement: 2 단계, 이미지 3개 중 2개 Dell Latitude D620 CD Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
    댓글 쓰기
  3. Dell Latitude D620 CD Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the top portion of the keyboard using a #00 screwdriver
    댓글 쓰기
  4. Dell Latitude D620 CD Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
    댓글 쓰기
  5. Dell Latitude D620 CD Drive Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude D620 CD Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Once keyboard is out of the case, lay it face-down on the track pad
    댓글 쓰기
  6. Dell Latitude D620 CD Drive Replacement: 6 단계, 이미지 2개 중 1개 Dell Latitude D620 CD Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Using a small spudger, pull back on the black bar to release the blue lever
    댓글 쓰기
  7. Dell Latitude D620 CD Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
    댓글 쓰기
  8. Dell Latitude D620 CD Drive Replacement, CD Drive: 8 단계, 이미지 2개 중 1개 Dell Latitude D620 CD Drive Replacement, CD Drive: 8 단계, 이미지 2개 중 2개
    • Press in the tab on the bottom right side of the CD drive
    • The tab comes out on its own; there is no need to pull it out manually.
    댓글 쓰기
  9. Dell Latitude D620 CD Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Gently pull the tab to remove the disk tray.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ivan
회원 가입일: 04/15/10
203 평판
안내서 1개를 작성함
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 회원
CPSU-REGAN-S10S24G35
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 68
전체 시간: 9,005
