주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude D820 Keyboard Replacement
필요한 것
    1. Dell Latitude D820 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Remove the charger from the laptop.
      • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
      • If you are replacing other components, leave the battery out.
      • If you are only replacing the battery, reverse the steps to install a new battery.
      댓글 쓰기
    1. Dell Latitude D820 Keyboard Replacement, Keyboard: 2 단계, 이미지 3개 중 1개 Dell Latitude D820 Keyboard Replacement, Keyboard: 2 단계, 이미지 3개 중 2개 Dell Latitude D820 Keyboard Replacement, Keyboard: 2 단계, 이미지 3개 중 3개
      • Open laptop lid and extend screen until it is parallel with the keyboard.
      • Locate the notch in the upper right corner of the keyboard (just above the 'page up' button).
      • Insert the plastic spudger and very gently lift the faceplate. It will make a soft snapping sound.
      • Set aside.
      댓글 쓰기
    2. Dell Latitude D820 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
      • Locate the three philips head screws above the keyboard. One is above the 'Pause/Break' key; one above the F7 key and one above the 'Esc' key. Remove all three.
      댓글 쓰기
    3. Dell Latitude D820 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
      • Gently lift top of keyboard and lay forward on palm rest.
      • Locate blue pull tab and gently disconnect ribbon cable from motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Michael Coleman
회원 가입일: 09/09/14
162 평판
안내서 1개를 작성함
Pasco Hernando, Team 1-2, Prince Fall 2014 Pasco Hernando, Team 1-2, Prince Fall 2014 회원
PHSC-PRINCE-F14S1G2
10 회원들
안내서 42개를 작성함
4가이드 댓글
I am the author of a high-altitude cookbook. I self-publish. My "A" key decided to stop working on my dell XP, and then the internet would not connect. When I finally purchased a new computer Windows 8, I discovered I could not format it for my hp business injet 2300. This printer is a duplexer, and key to my cookbook business. The other problem was Quark Express 6.1 would not work on it. Two thousand plus seemed a little high for a new Quark. After fiddling around with the internal keyboard and using the "copy and replace function" I decided on a new keyboard. Found a new one on ebay cheap. The instructions here were a blessing. Thank you, thank you, thank you! I now have my XP back working like new. The Windows 8 can be for the internet,
DAWN KLEIN - 답글 공유
Thank you very much. I am glad it helped and your back up and running. Just a side note: Be careful using Windows XP on the Internet these days, since it no longer receives security updates from Microsoft. Thanks again!
Henry - 답글 공유
You gave great directions. I never reassembled something I took apart. Worked like a charm Thanks so much!!!
Cheryl Baynard - 답글 공유
Beautifully clear - perfect! Thank you.
David Harmsworth - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 43
전체 시간: 2,636
