주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Optiplex GX620 CMOS Battery Replacement
필요한 것
  1. Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2개 중 1개 Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2개 중 2개
    • Power down your PC and remove the power cord from the back.
    댓글 쓰기
  2. Dell Optiplex GX620 CMOS Battery Replacement: 2 단계, 이미지 2개 중 1개 Dell Optiplex GX620 CMOS Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
    댓글 쓰기
  3. Dell Optiplex GX620 CMOS Battery Replacement, Dell Optiplex GX620 Side Panel Disassembly: 3 단계, 이미지 1개 중 1개
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
    댓글 쓰기
  4. Dell Optiplex GX620 CMOS Battery Replacement, Removing the CMOS Battery: 4 단계, 이미지 1개 중 1개
    • Insert a tool beside the battery and gently pry the battery out.
    • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kristina
회원 가입일: 09/03/14
213 평판
안내서 7개를 작성함
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 회원
PHSC-PRINCE-F14S5G1
10 회원들
안내서 15개를 작성함
2가이드 댓글
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - 답글 공유
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 87
전체 시간: 17,379
