주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Optiplex GX620 Floppy Drive Replacement
필요한 것
    1. Dell Optiplex GX620 Floppy Drive Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2개 중 1개 Dell Optiplex GX620 Floppy Drive Replacement, How to unplug and discharge before repair: 1 단계, 이미지 2개 중 2개
      • Power down your PC and remove the power cord from the back.
      댓글 쓰기
    2. Dell Optiplex GX620 Floppy Drive Replacement: 2 단계, 이미지 2개 중 1개 Dell Optiplex GX620 Floppy Drive Replacement: 2 단계, 이미지 2개 중 2개
      • Press and hold the power button for about 10 seconds, then release.
      • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
      댓글 쓰기
    1. Dell Optiplex GX620 Floppy Drive Replacement, Dell Optiplex GX620 Side Panel Disassembly: 3 단계, 이미지 1개 중 1개
      • With the computer standing upright, firmly pull on the tab at the back of the computer.
      • When the side panel pops free, gently pull the panel away from the computer.
      • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
      댓글 쓰기
    1. Dell Optiplex GX620 Floppy Drive Replacement, Remove the drive panel: 4 단계, 이미지 1개 중 1개
      • Slide the blue latch downward until the panel can be removed from it's hinges.
      댓글 쓰기
    2. Dell Optiplex GX620 Floppy Drive Replacement, Disconnect the cables: 5 단계, 이미지 1개 중 1개
      • Gently remove the floppy-drive and power cables from the back of the floppy drive.
      댓글 쓰기
    3. Dell Optiplex GX620 Floppy Drive Replacement, Remove the screws: 6 단계, 이미지 1개 중 1개
      • With a Phillips #1 screwdriver, remove the screws connecting the floppy drive to the drive bay. Set the screws aside in a location where you may use them at a later time.
      댓글 쓰기
    4. Dell Optiplex GX620 Floppy Drive Replacement, Remove the floppy drive: 7 단계, 이미지 1개 중 1개
      • To remove the unconnected floppy drive from the drive bay, slide the drive towards the front of the computer.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kristina
회원 가입일: 09/03/14
213 평판
안내서 7개를 작성함
Pasco Hernando, Team 5-1, Prince Fall 2014 Pasco Hernando, Team 5-1, Prince Fall 2014 회원
PHSC-PRINCE-F14S5G1
10 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 2,017
