주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Precision 3510 Display Assembly Replacement
필요한 것
  1. Dell Precision 3510 Display Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Precision 3510 Display Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the computer over so that you are looking at the bottom.
    • Use a Phillips #000 screwdriver to remove the eight 6.5 mm screws from the base cover.
    댓글 쓰기
  2. Dell Precision 3510 Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Use the opening tool to carefully pry the base cover from the computer.
    • Remove the base cover from the laptop.
    댓글 쓰기
  3. Dell Precision 3510 Display Assembly Replacement: 3 단계, 이미지 2개 중 1개 Dell Precision 3510 Display Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #000 screwdriver, remove the two 5.5 mm screws from the battery.
    댓글 쓰기
  4. Dell Precision 3510 Display Assembly Replacement: 4 단계, 이미지 2개 중 1개 Dell Precision 3510 Display Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Gently unplug the cable connected to the top of the battery.
    • Remove the battery from the laptop.
    댓글 쓰기
  5. Dell Precision 3510 Display Assembly Replacement, Power Connector Port: 5 단계, 이미지 2개 중 1개 Dell Precision 3510 Display Assembly Replacement, Power Connector Port: 5 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw from the metal bracket that secures the power port.
    댓글 쓰기
  6. Dell Precision 3510 Display Assembly Replacement: 6 단계, 이미지 2개 중 1개 Dell Precision 3510 Display Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the metal bracket and gently remove the power connector port.
    • Unplug the power connector port cable from the system board.
    댓글 쓰기
  7. Dell Precision 3510 Display Assembly Replacement, WLAN Card: 7 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the metal bracket to the WLAN card.
    • Remove the metal bracket from the system board.
    댓글 쓰기
  8. Dell Precision 3510 Display Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully detach the two cables that are connected to the WLAN card.
    댓글 쓰기
  9. Dell Precision 3510 Display Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the WLAN card from the system board.
    댓글 쓰기
  10. Dell Precision 3510 Display Assembly Replacement, Display Assembly: 10 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to remove the 6.5 mm screws from each display hinge bracket.
    • Remove the two hinge brackets from the computer.
    댓글 쓰기
  11. Dell Precision 3510 Display Assembly Replacement: 11 단계, 이미지 1개 중 1개
    • Carefully unroute the WLAN cables from the system board.
    댓글 쓰기
  12. Dell Precision 3510 Display Assembly Replacement: 12 단계, 이미지 3개 중 1개 Dell Precision 3510 Display Assembly Replacement: 12 단계, 이미지 3개 중 2개 Dell Precision 3510 Display Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to remove the 3 mm screw from the metal bracket that secures the eDP cable.
    • Gently disconnect the eDP cable from the system board.
    • Unroute the display cable from the system board.
    댓글 쓰기
  13. Dell Precision 3510 Display Assembly Replacement: 13 단계, 이미지 2개 중 1개 Dell Precision 3510 Display Assembly Replacement: 13 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the four 4.5 mm screws that secure the display assembly to the system board.
    • Flip the computer face up.
    • Carefully remove the WLAN cables and the display cable from the laptop.
    댓글 쓰기
  14. Dell Precision 3510 Display Assembly Replacement: 14 단계, 이미지 1개 중 1개
    • Detach the display assembly from the system board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Makenna Patrick
회원 가입일: 09/24/25
643 평판
안내서 5개를 작성함
Texas Tech, Team 46-3, Johansen Fall 2025 Texas Tech, Team 46-3, Johansen Fall 2025 회원
TTU-JOHANSEN-F25S46G3
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 30
전체 시간: 187
