주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Precision 3541 Battery Replacement
필요한 것
  1. Dell Precision 3541 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell Precision 3541 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell Precision 3541 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • The first step for battery replacement is to remove the base cover which is the bottom panel of the device. You will find a total of eight small screws, three on each side, and two in the middle of the panel. Once all screws are removed, it may be helpful to use a flat, pointy tool such as a paint key, to pop the panel off of the device.
    댓글 쓰기
  2. Dell Precision 3541 Battery Replacement: 2 단계, 이미지 2개 중 1개 Dell Precision 3541 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Once looking at the interior of the underbody, you should find a rectangular encasement panel in the bottom right corner of the device. This component is the battery. On the battery, you will find one screw on the right side and two on the top. Unscrew all three carefully, putting them in a safe holding place.
    댓글 쓰기
  3. Dell Precision 3541 Battery Replacement: 3 단계, 이미지 3개 중 1개 Dell Precision 3541 Battery Replacement: 3 단계, 이미지 3개 중 2개 Dell Precision 3541 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Locate a small black cable that runs along a crevice in the underside of the battery that connects the bottom of the battery to the device. Carefully unplug the side that connects into the battery and remove the cable from its crevice. Then the battery can be removed.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Abby Lunday
회원 가입일: 02/26/26
231 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 46
전체 시간: 58
