주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Precision 7520 Memory Module Replacement
필요한 것
  1. Dell Precision 7520 Memory Module Replacement, Battery Cover: 1 단계, 이미지 1개 중 1개
    • Slide the release latch towards the unlock icon to release the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
    댓글 쓰기
  2. Dell Precision 7520 Memory Module Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Slide the release latch towards from the unlock icon to unlock the battery[1].
    • Lift and remove the battery from the computer [2].
    댓글 쓰기
  3. Dell Precision 7520 Memory Module Replacement, Hard Drive: 3 단계, 이미지 1개 중 1개
    • Remove the M3.0x3.0 screws that secure the hard drive to the computer [1].
    • Lift the hard drive latch to release the hard drive [2].
    • Slide and lift the hard drive from the computer [3].
    댓글 쓰기
  4. Dell Precision 7520 Memory Module Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the M3.0x3.0 screws that secure the hard drive. Lift the hard drive from the bracket.
    댓글 쓰기
  5. Dell Precision 7520 Memory Module Replacement, KeyBoard: 5 단계, 이미지 1개 중 1개
    • Peel the tape to access the keyboard cable [1].
    • Disconnect the keyboard cables from the system board [2]
    댓글 쓰기
  6. Dell Precision 7520 Memory Module Replacement: 6 단계, 이미지 1개 중 1개
    • Using plastic scribe pry the keyboard trim from the bottom and work along the top edge and remove it from the computer [1, 2,3].
    • Remove the M2.0x2.5 screws that secure the keyboard to the computer [4].
    • Lift and slide the keyboard to remove it away from the computer [5].
    댓글 쓰기
  7. Dell Precision 7520 Memory Module Replacement, Memory Module: 7 단계, 이미지 1개 중 1개
    • Pry the retention clips away from the memory module until it pops up
    • Lift the memory module and remove it from the computer.
    댓글 쓰기
  8. Dell Precision 7520 Memory Module Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the screw that secures the memory shield [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
46,158 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 2,003개를 작성함
3가이드 댓글
Maybe reorder the steps so that if you only need to get to Dimm 0 and 1, do steps 1, 2, and 7, and add a step for removing the plate by pushing up on it after removing the other two screws. By these instructions, I thought just to get that second panel off, I had to do all steps, I got the keyboard off and everything only to realize, it was taking me into dimm 2 and 3 under the keyboard, which I did not need.
Nater Tater - 답글 공유
it would help complete newbies like myself if you could CLARIFY that you need to flip up the cable guards of the keyboard cables to release the cables because I accidentally popped out one of the cable guards and couldnt get it back into place… if the way the cable guards were to be released had been explained in plain english it would have prevented the mishap.
Thomas Smith - 답글 공유
As a test, I have moved the RAM from the dock in Step 7 (the back of the laptop) to the dock in Step 8 (under the keyboard), but I could not reboot, I then reversed it again (put the RAM in the module in Step 7 and it worked again.
Why is that? I have a Precision 7520,
Thanks
Maurizio Garzelli - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 56
전체 시간: 7,727
