주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Precision 7710 Memory Module Replacement
필요한 것
  1. Dell Precision 7710 Memory Module Replacement, Battery Cover: 1 단계, 이미지 1개 중 1개
    • Slide the release latch to unlock the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
    댓글 쓰기
  2. Dell Precision 7710 Memory Module Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Slide the release latch to unlock the battery [1].
    • Lift and remove the battery from the computer [2].
    댓글 쓰기
  3. Dell Precision 7710 Memory Module Replacement, Base Cover: 3 단계, 이미지 1개 중 1개
    • Remove the screws that secure the base cover to the computer [1].
    • Slide and lift the base cover away from the computer [2].
    댓글 쓰기
  4. Dell Precision 7710 Memory Module Replacement, KeyBoard: 4 단계, 이미지 2개 중 1개 Dell Precision 7710 Memory Module Replacement, KeyBoard: 4 단계, 이미지 2개 중 2개
    • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
    • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
    댓글 쓰기
  5. Dell Precision 7710 Memory Module Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the screws that secure the keyboard to the computer [1].
    • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
    댓글 쓰기
  6. Dell Precision 7710 Memory Module Replacement, Memory Module: 6 단계, 이미지 1개 중 1개
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
    댓글 쓰기
  7. Dell Precision 7710 Memory Module Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the screw that secures the memory shield to the computer [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
46,158 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 2,003개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 32
전체 시간: 2,400
