주요 콘텐츠로 건너뛰기
Dell Precision M3800 Keyboard Replacement
필요한 것
  1. Dell Precision M3800 Keyboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Dell Precision M3800 Keyboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
    there are 2 additional screws under the metal plate
    Andrew Gaquin - 답글
    That's right, at first time I tried carefully remove the back plate , with no success, {nly few minutes later I realized it were these 2 screws holding it all together and fighting against my intrusive dids
    Alexander Fediushyn -
    Thanks for the tip! I corrected the step to include this.
    Arthur Shi -
  2. Dell Precision M3800 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Keyboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Keyboard Replacement, RAM (Memory): 4 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement, RAM (Memory): 4 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement, RAM (Memory): 4 단계, 이미지 3개 중 3개
    • Pull the small silver RAM tabs outwards to pop it out of its place in the laptop body.
    • Remove the RAM from the laptop body (it should easily come out after pulling the silver tabs).
  5. Dell Precision M3800 Keyboard Replacement, USB Port: 5 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement, USB Port: 5 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement, USB Port: 5 단계, 이미지 3개 중 3개
    • Disconnect the orange wire with the two pull tabs by pulling upwards on the pull tabs.
  6. Dell Precision M3800 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the single 3.5 mm screw at the top of the left side holding the silver bracket using a Phillips #00 screwdriver.
    • Remove the LAN chip by pulling from the top away from the connector.
  7. Dell Precision M3800 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Disconnect the wires that are connected to left side of the motherboard with a hooked prying tool.
  8. Dell Precision M3800 Keyboard Replacement: 8 단계, 이미지 2개 중 1개 Dell Precision M3800 Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the black wire that is connected to left side of the motherboard.
  9. Dell Precision M3800 Keyboard Replacement: 9 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement: 9 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Unscrew the three 3.5 mm screws that secure the circuit board using a Phillips #00 screwdriver.
    • Remove the circuit board by lifting upward.
    • To fully remove the USB ports from the circuit board, you'll need to desolder the points. Use the How to Solder and Desolder Connections guide for more information on soldering and desoldering connections.
  10. Dell Precision M3800 Keyboard Replacement, Fan: 10 단계, 이미지 2개 중 1개 Dell Precision M3800 Keyboard Replacement, Fan: 10 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
  11. Dell Precision M3800 Keyboard Replacement: 11 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement: 11 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement: 11 단계, 이미지 3개 중 3개
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
  12. Dell Precision M3800 Keyboard Replacement: 12 단계, 이미지 2개 중 1개 Dell Precision M3800 Keyboard Replacement: 12 단계, 이미지 2개 중 2개
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
  13. Dell Precision M3800 Keyboard Replacement, Keyboard: 13 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement, Keyboard: 13 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement, Keyboard: 13 단계, 이미지 3개 중 3개
    • Disconnect the 6 wires that are attached to the motherboard.
    • Three of the six wires have a clasp holding the wire. Pull up on the tab and remove the wire.
    • The other three wires have pull tabs and can be removed by pulling from the connector of the wire.
  14. Dell Precision M3800 Keyboard Replacement: 14 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement: 14 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement: 14 단계, 이미지 3개 중 3개
    • Unscrew the six 3.5mm screws using the Phillips #00 screwdriver.
    • Lift the motherboard out of the laptop body to expose the backing of the keyboard.
  15. Dell Precision M3800 Keyboard Replacement: 15 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement: 15 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement: 15 단계, 이미지 3개 중 3개
    • Remove the black piece of tape at the top of the keyboard.
    • Unscrew the fifteen screws with a 2 millimeter 000 Philips Head.
    Consider there's more screws, all the one with a "K" letter, also there's a protective layer of copper with some adhesive, this layer is almost imposible to reuse, but take care removing and possible you can reuse on the new keyboard
    Juvenal Guzman - 답글
  16. Dell Precision M3800 Keyboard Replacement: 16 단계, 이미지 3개 중 1개 Dell Precision M3800 Keyboard Replacement: 16 단계, 이미지 3개 중 2개 Dell Precision M3800 Keyboard Replacement: 16 단계, 이미지 3개 중 3개
    • Using a prying tool, place wedges underneath the keyboard until the entire keyboard is removed.
    Important note missing from the guide, under the K’s on the back of the keyboard is another 13 screws if you dont remove these before trying to pry the keyboard up you are gonna have a bad time
    Andrew Gaquin - 답글
    There is no need to use prying tools, you need to remove 28 screws. there is 1 screw per K marker in the back of the keyboard.
    If all these screws are not removed, you will damage the Palmrest
    Augusto De La Espriella - 답글
결론
작성자
4다른 기여자 명과 함께
Brianna Hitchcock
회원 가입일: 09/17/19
885 평판
안내서 7개를 작성함
댓글 한 개
Reminder: There are more than 15 screws to unscrew on the keyboard (Step 14). They’re hidden under the “K”s.
You shouldn’t apply force to remove the keyboard.
Felipe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 44
전체 시간: 2,748
