주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Precision T3400 RAM Replacement
필요한 것
    1. Dell Precision T3400 RAM Replacement, Power down the PC.: 1 단계, 이미지 1개 중 1개
      • If your PC is on, shut it down by navigating to the window tab in the bottom left corner, selecting the power icon, and then selecting shut down.
      • Unplug the PC from the wall.
      • Disconnect the power cable from the tower, unplug keyboards, monitors, or any other devices, and remove any USB devices.
      • Press the power button after completely shutting down the PC. This will "ground" the motherboard, preventing any short circuiting from occurring.
      댓글 쓰기
    1. Dell Precision T3400 RAM Replacement, Remove the computer's side panel.: 2 단계, 이미지 2개 중 1개 Dell Precision T3400 RAM Replacement, Remove the computer's side panel.: 2 단계, 이미지 2개 중 2개
      • Lay the computer on its side so the panel faces up.
      • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
      • Make sure the computer is on its side before you begin replacing any parts.
      댓글 쓰기
    1. Dell Precision T3400 RAM Replacement, Remove the RAM: 3 단계, 이미지 1개 중 1개
      • Press down on both of the two secure tabs on each side of the RAM stick.
      • When you simultaneously press each of the secure tabs, the RAM stick will move up and out of its slot.
      댓글 쓰기
    2. Dell Precision T3400 RAM Replacement, Re-install the new RAM: 4 단계, 이미지 1개 중 1개
      • Align the notch on the bottom of the RAM stick with the notch in the slot.
      • To avoid damage to the RAM, press the stick straight down into the slot using equal force on each end of the stick.
      • Insert the RAM stick into the slot until the stick snaps into position. If you insert the stick correctly, the secure tabs will snap into the notches on each side.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jill Shastany
회원 가입일: 09/21/13
218 평판
안내서 1개를 작성함
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G2
3 회원들
안내서 57개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 35
전체 시간: 3,775
