주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Precision T3400 Video Card Replacement
  1. Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: 1 단계, 이미지 2개 중 1개 Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: 1 단계, 이미지 2개 중 2개
    • Lay the computer on its side so the panel faces up.
    • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
    • Make sure the computer is on its side before you begin replacing any parts.
    댓글 쓰기
  2. Dell Precision T3400 Video Card Replacement, Move the heat-sink assembly lever out of the way: 2 단계, 이미지 1개 중 1개
    • Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
    • Make sure you ground yourself to prevent static discharge
    댓글 쓰기
  3. Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: 3 단계, 이미지 2개 중 1개 Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: 3 단계, 이미지 2개 중 2개
    • Squeeze the two release tabs together and pivot the secure hatch to the right to open.
    댓글 쓰기
  4. Dell Precision T3400 Video Card Replacement, Remove the video card: 4 단계, 이미지 1개 중 1개
    • Hold the card by its top corner and metal bracket and pull it out of its slot.
    댓글 쓰기
  5. Dell Precision T3400 Video Card Replacement, Install the new video card: 5 단계, 이미지 2개 중 1개 Dell Precision T3400 Video Card Replacement, Install the new video card: 5 단계, 이미지 2개 중 2개
    • Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
    • Close the card door and move the blue plastic secure lever back into place.\
    • Ensure that the card you are replacing the existing card with meets wattage and connectivity requirements. Do not force a card into the slot.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Step 1: Install new card and latch it in place. Step 2: Reinstall the side panel. Step 3: Plug everything back in
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Josette Cormier
회원 가입일: 09/10/13
13 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G2
3 회원들
안내서 14개를 작성함
1가이드 댓글
Does it have PCI-E 2.0?
What dimensions the graphics card can have?
Maxime Raguenet - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 69
전체 시간: 7,407
