주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell VRC100-R Touchpad Replacement
필요한 것
    1. Dell VRC100-R Touchpad Replacement, Battery: 1 단계, 이미지 3개 중 1개 Dell VRC100-R Touchpad Replacement, Battery: 1 단계, 이미지 3개 중 2개 Dell VRC100-R Touchpad Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      댓글 쓰기
    2. Dell VRC100-R Touchpad Replacement: 2 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      댓글 쓰기
    1. Dell VRC100-R Touchpad Replacement, Joystick: 3 단계, 이미지 3개 중 1개 Dell VRC100-R Touchpad Replacement, Joystick: 3 단계, 이미지 3개 중 2개 Dell VRC100-R Touchpad Replacement, Joystick: 3 단계, 이미지 3개 중 3개
      • Hold the joystick down with your left thumb to make space for the plastic opening tool.
      • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
      • Slide the plastic opening tool around the perimeter until you can lift the front panel.
      • You may hear a popping noise when you pry off the front panel.
      댓글 쓰기
    2. Dell VRC100-R Touchpad Replacement: 4 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 4 단계, 이미지 2개 중 2개
      • Grab the joystick and pull away from the controller to remove it.
      댓글 쓰기
    1. Dell VRC100-R Touchpad Replacement, Touchpad: 5 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement, Touchpad: 5 단계, 이미지 2개 중 2개
      • Remove one 6mm Phillips #0 screw.
      댓글 쓰기
    2. Dell VRC100-R Touchpad Replacement: 6 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 6 단계, 이미지 2개 중 2개
      • Turn your controller over and orient it so that the thin side is on the top.
      • Remove four 4mm Phillips #0 screws.
      댓글 쓰기
    3. Dell VRC100-R Touchpad Replacement: 7 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 7 단계, 이미지 2개 중 2개
      • Turn your controller 90 degrees clockwise and insert a plastic opening tool into the crease of the back panel.
      • Push down on the end of the plastic opening tool closest to you to lift the panel up.
      • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
      • You may hear loud popping noises as the back panel separates from the controller.
      댓글 쓰기
    4. Dell VRC100-R Touchpad Replacement: 8 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 8 단계, 이미지 2개 중 2개
      댓글 쓰기
    5. Dell VRC100-R Touchpad Replacement: 9 단계, 이미지 3개 중 1개 Dell VRC100-R Touchpad Replacement: 9 단계, 이미지 3개 중 2개 Dell VRC100-R Touchpad Replacement: 9 단계, 이미지 3개 중 3개
      • Use the tip of a plastic opening tool or your fingernail to gently flip-up the white locking flap.
      • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
      • Grab the blue cable and pull away from the socket.
      • To reinstall, insert the blue cable into the connector and close the flap on the black line.
      댓글 쓰기
    6. Dell VRC100-R Touchpad Replacement: 10 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 10 단계, 이미지 2개 중 2개
      • Place two fingers on the perimeter of the daughterboard and fold it down along the orange cable.
      댓글 쓰기
    7. Dell VRC100-R Touchpad Replacement: 11 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 11 단계, 이미지 2개 중 2개
      • Remove two black 6mm Phillips #0 screws.
      댓글 쓰기
    8. Dell VRC100-R Touchpad Replacement: 12 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 12 단계, 이미지 2개 중 2개
      • Pinch the black ring on the top of your controller and pull toward yourself to disconnect it.
      댓글 쓰기
    9. Dell VRC100-R Touchpad Replacement: 13 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 13 단계, 이미지 2개 중 2개
      • Remove three 3mm Phillips #0 screws.
      댓글 쓰기
    10. Dell VRC100-R Touchpad Replacement: 14 단계, 이미지 2개 중 1개 Dell VRC100-R Touchpad Replacement: 14 단계, 이미지 2개 중 2개
      • Insert your finger underneath the black plastic "V" and scoop up to remove it.
      댓글 쓰기
    11. Dell VRC100-R Touchpad Replacement: 15 단계, 이미지 3개 중 1개 Dell VRC100-R Touchpad Replacement: 15 단계, 이미지 3개 중 2개 Dell VRC100-R Touchpad Replacement: 15 단계, 이미지 3개 중 3개
      • Place your thumb on the outer edge of the touchpad on the other side of the controller.
      • Push toward the center of the circle to get your fingernail underneath the touchpad then scoop away from yourself.
      • You can see the detachable black flaps underneath the touchpad along the perimeter.
      • Turn your controller over and remove the touchpad.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Steven Pineda
회원 가입일: 04/16/18
1,049 평판
안내서 3개를 작성함
Cal Poly, Team S18-G3, Livingston Spring 2018 Cal Poly, Team S18-G3, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G3
4 회원들
안내서 15개를 작성함
1가이드 댓글
where to get the replacement for touchpad?
Kenneth Alvarez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 1,525
