주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Venue 8 Display Replacement
필요한 것
  1. Dell Venue 8 Display Replacement, Rear Case/Midframe: 1 단계, 이미지 1개 중 1개
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
    댓글 쓰기
  2. Dell Venue 8 Display Replacement: 2 단계, 이미지 3개 중 1개 Dell Venue 8 Display Replacement: 2 단계, 이미지 3개 중 2개 Dell Venue 8 Display Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
    댓글 쓰기
  3. Dell Venue 8 Display Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
    댓글 쓰기
  4. Dell Venue 8 Display Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pry the battery away from the device with the plastic opening tool to remove it.
    • The battery is held on to the tablet by a light adhesive
    댓글 쓰기
  5. Dell Venue 8 Display Replacement, Speaker: 5 단계, 이미지 1개 중 1개
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
    댓글 쓰기
  6. Dell Venue 8 Display Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
    댓글 쓰기
  7. Dell Venue 8 Display Replacement, Display: 7 단계, 이미지 2개 중 1개 Dell Venue 8 Display Replacement, Display: 7 단계, 이미지 2개 중 2개
    • Disconnect the display clip found next to the speaker.
    • Disconnect the Display connection located at the top of the tablet.
    댓글 쓰기
  8. Dell Venue 8 Display Replacement: 8 단계, 이미지 1개 중 1개
    • Unclip the logic board from the Display.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mitul
회원 가입일: 02/19/15
673 평판
안내서 1개를 작성함
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015 회원
USFT-LEAHY-W15S9G2
3 회원들
안내서 12개를 작성함
2가이드 댓글
LOL. Who rated this as a difficult repair? Seriously? T5 screws too much for you? The only issue with the repair for this device is the adhesive between the digi and frame is a REAL pain to remove, and the plastic frame is likely to melt if you use too much/high heat. Otherwise, it's very simple. Just be careful when installing the new digi, as the motherboard needs to be slightly lifted to feed the connector.
Rene - 답글 공유
Thanks for the instructions!
Is there a part 2 for this guide? The instructions is incomplete and doesn't not include steps to actually remove the digitizer.
Franklin Ramos - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 40
전체 시간: 7,684
