주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Venue Pro Volume Button Replacement
필요한 것
    1. Dell Venue Pro Volume Button Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Slide the back cover up.
      • Lift the back cover away from the device completely.
      댓글 쓰기
    1. Dell Venue Pro Volume Button Replacement, Battery: 2 단계, 이미지 2개 중 1개 Dell Venue Pro Volume Button Replacement, Battery: 2 단계, 이미지 2개 중 2개
      • Use your finger to lift the battery using the notch in the upper left corner of the compartment.
      댓글 쓰기
    1. Dell Venue Pro Volume Button Replacement, Volume Button: 3 단계, 이미지 1개 중 1개
      • Remove the Back Cover
      • Slide and lift the back cover off the phone. (Use the existing Back Cover Removal guide as reference)
      댓글 쓰기
    2. Dell Venue Pro Volume Button Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the Battery
      • Lift the battery out of its compartment and set it aside.
      댓글 쓰기
    3. Dell Venue Pro Volume Button Replacement: 5 단계, 이미지 2개 중 1개 Dell Venue Pro Volume Button Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the Midframe Screws
      • Use a Phillips #00 screwdriver to remove the 4.57 mm screws securing the midframe to the phone.
      • Keep track of each screw and its original location to ensure correct reassembly.
      • Mixing screw lengths can damage internal components during reassembly.
      댓글 쓰기
    4. Dell Venue Pro Volume Button Replacement: 6 단계, 이미지 2개 중 1개 Dell Venue Pro Volume Button Replacement: 6 단계, 이미지 2개 중 2개
      • Insert a plastic opening tool into the seam between the midframe and phone body.
      • Gently twist the tool to release the clips around the edges.
      • Once all clips have disengaged, pull the midframe upward to remove it completely.
      • If the midframe resists, continue sliding the tool along the seam until every clip releases.
      댓글 쓰기
    5. Dell Venue Pro Volume Button Replacement: 7 단계, 이미지 1개 중 1개
      • Expose the Motherboard
      • With the midframe removed, the motherboard should now be fully visible.
      • Identify the following components before continuing:
      • SIM card reader near the top of the device
      • Metal shielding covering the center of the motherboard
      • Micro-USB charging port at the bottom
      • Secondary daughterboard connection on the left side
      • Set the midframe aside.
      댓글 쓰기
    6. Dell Venue Pro Volume Button Replacement: 8 단계, 이미지 2개 중 1개 Dell Venue Pro Volume Button Replacement: 8 단계, 이미지 2개 중 2개
      • Disconnect Internal Cables
      • At this point, the motherboard should be fully visible, as shown in your reference photos. You should see:
      • Disconnect the following cables:
      • Display cable
      • Any remaining flex cables attached to the motherboard
      • Lift connectors straight up—do not pull on the cables.
      댓글 쓰기
    7. Dell Venue Pro Volume Button Replacement: 9 단계, 이미지 2개 중 1개 Dell Venue Pro Volume Button Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the Motherboard Screws
      • Use a Phillips #00 screwdriver to remove the 2.68 mm screws securing the motherboard to the frame.
      • Screws are located near:
      • The bottom right corner (charging port area)
      • The middle left side
      • The top of the motherboard
      • Set all screws aside.
      • Using longer screws in motherboard locations can cause permanent damage.
      댓글 쓰기
    8. Dell Venue Pro Volume Button Replacement: 10 단계, 이미지 2개 중 1개 Dell Venue Pro Volume Button Replacement: 10 단계, 이미지 2개 중 2개
      • Starting from the top edge, gently lift the motherboard up and away from the phone housing.
      • The micro-USB charging port may fit snugly in its opening. Lift carefully to avoid bending the board.
      • Once free, remove the motherboard from the device. Set the motherboard aside.
      • Do not flex or twist the motherboard during removal.
      댓글 쓰기
    9. Dell Venue Pro Volume Button Replacement: 11 단계, 이미지 2개 중 1개 Dell Venue Pro Volume Button Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the Volume Button Assembly
      • Locate the volume button assembly along the side of the phone frame.
      • Lift the volume button assembly out of its recess.
      • The button contacts are delicate. Remove the assembly carefully.
      댓글 쓰기
    10. Dell Venue Pro Volume Button Replacement: 12 단계, 이미지 1개 중 1개
      • Install the New Volume Button Assembly
      • Place the replacement volume button assembly into the phone frame.
      • Ensure it sits flush and aligns correctly with the external button openings.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Todjay A Orr
회원 가입일: 10/29/25
719 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 119
