주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Vostro 15 Memory Module Replacement
필요한 것
  1. Dell Vostro 15 Memory Module Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the battery release latches until they click into place.
    • Slide the battery out of the battery bay.
    댓글 쓰기
  2. Dell Vostro 15 Memory Module Replacement, Hinge Cover: 2 단계, 이미지 1개 중 1개
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
    댓글 쓰기
  3. Dell Vostro 15 Memory Module Replacement, KeyBoard: 3 단계, 이미지 1개 중 1개
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • Rotate the keyboard connector latch upward to release the keyboard cable.
    • Slide the keyboard cable out of the keyboard connector.
    댓글 쓰기
  4. Dell Vostro 15 Memory Module Replacement, Memory Module: 4 단계, 이미지 1개 중 1개
    • Lift the memory module cover But Do Not Remove It.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
46,158 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 2,003개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 27
전체 시간: 302
