주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Vostro A860 Keyboard Replacement
필요한 것
  1. Dell Vostro A860 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 Dell Vostro A860 Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Make sure the computer is powered down before beginning your work
    • Remove the battery and set it aside, there is a small clip that slides to free the battery.
    • Unscrew the two 4.7mm screws below the battery.
    댓글 쓰기
  2. Dell Vostro A860 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Dell Vostro A860 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove seven 8.6mm screws from the left and right side of the battery compartment
    • There are 2 screws to the left of the compartment, 3 to the right, and 2 along the bottom side.
    댓글 쓰기
  3. Dell Vostro A860 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Dell Vostro A860 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Dell Vostro A860 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Flip the laptop over and open it up.
    • Using a plastic opening tool carefully pry up along the edge of the plastic bezel at the top of the keyboard.
    • Getting the lip of the plastic opening tool under the edge of the bezel and moving it along the right and left edges helps to make removal easier.
    댓글 쓰기
  4. Dell Vostro A860 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Dell Vostro A860 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove two 5.5mm screws from the top of the keyboard
    • Using a plastic opening tool push inward along the edges of the keyboard to release the holding clips
    댓글 쓰기
  5. Dell Vostro A860 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the keyboard upwards
    • Be careful not to pull too hard on the keyboard as it is still attached to the laptop by the ribbon connector.
    • Using the plastic opening tool push up on the black clip holding the connector ribbon.
    • Pull out the ribbon connector to remove the keyboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Joshua Dennis
회원 가입일: 03/25/16
528 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-5, Miles Spring 2016 UMass Dartmouth, Team 1-5, Miles Spring 2016 회원
UMASSD-MILES-S16S1G5
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 15
전체 시간: 926
