주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Vostro V130 Memory Module Replacement
필요한 것
  1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • Remove the screws that secure the base cover to the computer.
    댓글 쓰기
  2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: 2 단계, 이미지 1개 중 1개
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
    댓글 쓰기
  3. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: 3 단계, 이미지 1개 중 1개
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
    댓글 쓰기
  4. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: 4 단계, 이미지 1개 중 1개
    • Remove the screws that secure the battery to the computer.
    댓글 쓰기
  5. Dell Vostro V130 Memory Module Replacement, Lift the Battery: 5 단계, 이미지 1개 중 1개
    • Lift the battery up and away from the computer.
    댓글 쓰기
  6. Dell Vostro V130 Memory Module Replacement, LED Cover: 6 단계, 이미지 1개 중 1개
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
    댓글 쓰기
  7. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: 7 단계, 이미지 1개 중 1개
    • Pull the LED cover toward the keyboard and remove it from the computer.
    댓글 쓰기
  8. Dell Vostro V130 Memory Module Replacement, Memory Module: 8 단계, 이미지 1개 중 1개
    • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    댓글 쓰기
  9. Dell Vostro V130 Memory Module Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
46,158 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 2,003개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 23
전체 시간: 613
