소개
If your Dell XPS 13 7390 has lost its ability to hold a charge, you probably have a dead battery that needs to be replaced.
A working Dell XPS 13 7390 battery provides power to your computer. Laptop batteries discharge more quickly after a large number of charge cycles. If you notice that your battery is discharging faster than usual, perform a battery calibration to accurately determine its charge capacity. If you continue to notice large drops in charge percentage, you should replace your battery.
A punctured Dell XPS 13 7390 battery can start a fire. If your battery is swollen, take appropriate precautions.
Be sure to turn off your device before you begin.
필요한 것
Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
With the computer face-down, open the computer at an angle.
Using a plastic scribe, pry the base cover from the palm-rest assembly, starting at the front left and right corners.
Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
Lift the base cover from the palm-rest assembly.
Ensure that the battery cable is disconnected from the system board.
Remove the four screws (M2x2) that secure the battery to the palm-rest assembly
Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
Lift the battery off the palm-rest assembly.
Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
Align the screw holes on the battery with the screw holes on the palm-rest assembly.
Replace the four screws (M2x2) that secure the battery to the palm-rest assembly.
Replace the screw (M1.6x4) that secures the battery to the palm-rest assembly
Align the screw holes on the base cover with the screw holes on the palm-rest assembly and slide in the base cover into place.
Replace the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
Congratulations, you’re all done!
다른 11명이 해당 안내서를 완성하였습니다.
댓글 3개
I have an xps 13 7390 and when I perform step 1 - prying open the base cover - the computer turns on. I searched the internet for how to configure my PC to not automatically power on when the lid opens (even when it's only opened 1/4 of the way it tries to turn on) and my BIOS does not seem to have a Power On - Lid Open on/off option. Any suggestions? Thanks.
This guide is better and more accurate than Dell’s website. Just replaced the battery DHGH8 (4-cell 52 Wh, 7.6 V) in my XPS 7390 with no problems.
