주요 콘텐츠로 건너뛰기
Dell XPS 13 9310 Battery Replacement
필요한 것
  1. Dell XPS 13 9310 Battery Replacement, Unfasten the lower case: 1 단계, 이미지 1/2 Dell XPS 13 9310 Battery Replacement, Unfasten the lower case: 1 단계, 이미지 2/2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9310 Battery Replacement, Insert an opening pick: 2 단계, 이미지 1/2 Dell XPS 13 9310 Battery Replacement, Insert an opening pick: 2 단계, 이미지 2/2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9310 Battery Replacement, Release the case's front clips: 3 단계, 이미지 1/2 Dell XPS 13 9310 Battery Replacement, Release the case's front clips: 3 단계, 이미지 2/2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9310 Battery Replacement, Release the remaining clips: 4 단계, 이미지 1/3 Dell XPS 13 9310 Battery Replacement, Release the remaining clips: 4 단계, 이미지 2/3 Dell XPS 13 9310 Battery Replacement, Release the remaining clips: 4 단계, 이미지 3/3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9310 Battery Replacement: 5 단계, 이미지 1/3 Dell XPS 13 9310 Battery Replacement: 5 단계, 이미지 2/3 Dell XPS 13 9310 Battery Replacement: 5 단계, 이미지 3/3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  6. Dell XPS 13 9310 Battery Replacement, Disconnect the battery: 6 단계, 이미지 1/3 Dell XPS 13 9310 Battery Replacement, Disconnect the battery: 6 단계, 이미지 2/3 Dell XPS 13 9310 Battery Replacement, Disconnect the battery: 6 단계, 이미지 3/3
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
    • After you disconnect the battery, some of your laptop's startup (BIOS) settings will revert to their defaults.
    • You may need to run BIOS setup to reset the system clock as well as any specialized disk settings before you can boot up your XPS.
  7. Dell XPS 13 9310 Battery Replacement, Unfasten the battery: 7 단계, 이미지 1/2 Dell XPS 13 9310 Battery Replacement, Unfasten the battery: 7 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the five 2.8 mm-long screws securing the battery.
  8. Dell XPS 13 9310 Battery Replacement, Remove the battery: 8 단계, 이미지 1/3 Dell XPS 13 9310 Battery Replacement, Remove the battery: 8 단계, 이미지 2/3 Dell XPS 13 9310 Battery Replacement, Remove the battery: 8 단계, 이미지 3/3
    • Lift the battery straight out of its recess and remove it.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 2명이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
127,711 평판
안내서 592개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 89
30일 전: 373
전체 시간: 5,457
