주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell XPS 15 9510 Display Assembly Replacement
필요한 것
  1. Dell XPS 15 9510 Display Assembly Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
    댓글 쓰기
  2. Dell XPS 15 9510 Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
    댓글 쓰기
  3. Dell XPS 15 9510 Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the back panel of the laptop off and set it aside.
    댓글 쓰기
  4. Dell XPS 15 9510 Display Assembly Replacement, Display Assembly: 4 단계, 이미지 1개 중 1개
    • Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
    댓글 쓰기
  5. Dell XPS 15 9510 Display Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Remove five screws that connect the display using a Phillips #00 screwdriver.
    댓글 쓰기
  6. Dell XPS 15 9510 Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the display from the Dell XPS 15 9510.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Austin Sa
회원 가입일: 03/30/22
432 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-3, Mellen Spring 2022 UMass Dartmouth, Team 1-3, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S1G3
3 회원들
안내서 9개를 작성함
2가이드 댓글
Missing a very important step.
Two small screws above the display cable clamp - Step 5 - need to be removed. If you look at the picture in step 5, the far left red/orange circle actually contains one. You can spot it inside and at the top of the of the circle. You can't separate the display assembly without removing those 2 screws.
Joshua Kleier - 답글 공유
Aren't there any cables that need to be removed?
Ned Eff - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 146
전체 시간: 5,173
