주요 콘텐츠로 건너뛰기
Dell XPS 15 9510 Touchpad Replacement
필요한 것
  1. Dell XPS 15 9510 Touchpad Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Touchpad Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Touchpad Replacement, Fan: 4 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Touchpad Replacement, Fan: 4 단계, 이미지 2개 중 2개
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
  5. Dell XPS 15 9510 Touchpad Replacement: 5 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Touchpad Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Touchpad Replacement: 7 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Touchpad Replacement: 7 단계, 이미지 2개 중 2개
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Touchpad Replacement: 8 단계, 이미지 3개 중 1개 Dell XPS 15 9510 Touchpad Replacement: 8 단계, 이미지 3개 중 2개 Dell XPS 15 9510 Touchpad Replacement: 8 단계, 이미지 3개 중 3개
    • Repeat the previous step and remove the other fan.
  9. Dell XPS 15 9510 Touchpad Replacement, Battery: 9 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Touchpad Replacement, Battery: 9 단계, 이미지 2개 중 2개
    • Using the small battery pull tab, disconnect the battery connector from the motherboard.
  10. Dell XPS 15 9510 Touchpad Replacement: 10 단계, 이미지 1개 중 1개
    • Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
  11. Dell XPS 15 9510 Touchpad Replacement: 11 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Touchpad Replacement: 11 단계, 이미지 2개 중 2개
    • There are many delicate components in the vicinity of the battery, so be extremely careful removing it
    • Remove the old battery from the laptop.
  12. Dell XPS 15 9510 Touchpad Replacement, Heat Sink: 12 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Touchpad Replacement, Heat Sink: 12 단계, 이미지 2개 중 2개
    • Remove the three 4.6 mm screws that secure the heat sink with a Phillips #00 screwdriver.
  13. Dell XPS 15 9510 Touchpad Replacement: 13 단계, 이미지 1개 중 1개
  14. Dell XPS 15 9510 Touchpad Replacement, Touchpad: 14 단계, 이미지 1개 중 1개
    • Remove the six 3 mm screws securing the touch pad with a Phillips #00 screw driver.
  15. Dell XPS 15 9510 Touchpad Replacement: 15 단계, 이미지 3개 중 1개 Dell XPS 15 9510 Touchpad Replacement: 15 단계, 이미지 3개 중 2개 Dell XPS 15 9510 Touchpad Replacement: 15 단계, 이미지 3개 중 3개
    • Flip up the black ZIF locking flap that secures the touchpad ribbon cable.
    • Disconnect the touch pad ribbon cable.
  16. Dell XPS 15 9510 Touchpad Replacement: 16 단계, 이미지 2개 중 1개 Dell XPS 15 9510 Touchpad Replacement: 16 단계, 이미지 2개 중 2개
    • Lift the touch pad up and out of the chassis.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Esmie
회원 가입일: 09/23/24
121 평판
안내서 1개를 작성함
댓글 한 개
This guide is incomplete. Step 13 shows removing the heatsink, then step 14 is removing the touchpad, but it's a missing a HUGE series of steps in between which is removing the motherboard to access the touchpad. As-is this guide is not usable.
Derek Selby - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 38
전체 시간: 161
