소개
Glitching touchpads with erratic cursor movement, not being able to click with the touchpad, and the touchpad being unresponsive are signs that your current Dell XPS 15 9510 touchpad needs replacement.
필요한 것
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Lift the back panel of the laptop off and set it aside.
Please do not miss this warning of it being sharp...
After opening a few laptops for my office, I have generally been fine. But after opening my own XPS... I had sliced my finger badly. -
Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
I had to remove three screws in total to remove the right fan. One that is circled in the image above, and two more which hold the small black bracket to the right of the right fan. This bracket, while seemingly there to protect/secure a ribbon cable, also secures the right fan. Perhaps the guide should be corrected to account for this? or maybe there are multiple variants.
Using the small battery pull tab, disconnect the battery connector from the motherboard.
Remove the three 4.6 mm screws that secure the heat sink with a Phillips #00 screwdriver.
Lift and remove the heat sink.
Be sure to reapply thermal paste before replacing the heat sink.
Remove the six 3 mm screws securing the touch pad with a Phillips #00 screw driver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
This guide is incomplete. Step 13 shows removing the heatsink, then step 14 is removing the touchpad, but it's a missing a HUGE series of steps in between which is removing the motherboard to access the touchpad. As-is this guide is not usable.
