주요 콘텐츠로 건너뛰기
Dell XPS 15 9520 Battery Replacement
필요한 것
  1. Dell XPS 15 9520 Battery Replacement, Unfasten the back cover: 1 단계, 이미지 1/2 Dell XPS 15 9520 Battery Replacement, Unfasten the back cover: 1 단계, 이미지 2/2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.3 mm-long screws securing the back cover.
  2. Dell XPS 15 9520 Battery Replacement, Insert an opening pick: 2 단계, 이미지 1/2 Dell XPS 15 9520 Battery Replacement, Insert an opening pick: 2 단계, 이미지 2/2
    • Insert an opening pick between the bottom-left corner of the aluminum back cover and the chassis.
    • Leave the pick inserted before continuing to the next step.
  3. Dell XPS 15 9520 Battery Replacement, Release the corner clip: 3 단계, 이미지 1/2 Dell XPS 15 9520 Battery Replacement, Release the corner clip: 3 단계, 이미지 2/2
    • Insert the flat end of the spudger into the gap you just created.
    • Pry up to release the corner clips.
    • Repeat this process for the opposite corner of the back cover.
  4. Dell XPS 15 9520 Battery Replacement, Unclip the front edge: 4 단계, 이미지 1/3 Dell XPS 15 9520 Battery Replacement, Unclip the front edge: 4 단계, 이미지 2/3 Dell XPS 15 9520 Battery Replacement, Unclip the front edge: 4 단계, 이미지 3/3
    • Reinsert your opening pick under the aluminum cover at the front edge of the laptop.
    • Pry to loosen the cover.
    • Pry at multiple locations along the front edge to release all of the retaining clips.
    • Do not use a sliding motion along the front edge. This may damage cables near the trackpad.
  5. Dell XPS 15 9520 Battery Replacement, Remove the back cover: 5 단계, 이미지 1/3 Dell XPS 15 9520 Battery Replacement, Remove the back cover: 5 단계, 이미지 2/3 Dell XPS 15 9520 Battery Replacement, Remove the back cover: 5 단계, 이미지 3/3
    • The edges of the back cover are very sharp. Use caution when handling it.
    • Lift the back cover off the chassis and remove it.
    • If the back cover feels stuck to the chassis, use an opening pick to release any remaining clips around the back cover's perimeter.
  6. Dell XPS 15 9520 Battery Replacement, Disconnect the battery: 6 단계, 이미지 1/3 Dell XPS 15 9520 Battery Replacement, Disconnect the battery: 6 단계, 이미지 2/3 Dell XPS 15 9520 Battery Replacement, Disconnect the battery: 6 단계, 이미지 3/3
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  7. Dell XPS 15 9520 Battery Replacement, Remove the tape: 7 단계, 이미지 1/3 Dell XPS 15 9520 Battery Replacement, Remove the tape: 7 단계, 이미지 2/3 Dell XPS 15 9520 Battery Replacement, Remove the tape: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers, or your fingers, to peel back the tape connecting the speaker cable and the battery.
    • Repeat for the three other tape segments.
  8. Dell XPS 15 9520 Battery Replacement, Unfasten the battery: 8 단계, 이미지 1/2 Dell XPS 15 9520 Battery Replacement, Unfasten the battery: 8 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the eight screws securing the battery:
    • Four 4.4 mm-long screws
    • Four 3.4 mm-long screws
  9. Dell XPS 15 9520 Battery Replacement, Remove the battery: 9 단계, 이미지 1/3 Dell XPS 15 9520 Battery Replacement, Remove the battery: 9 단계, 이미지 2/3 Dell XPS 15 9520 Battery Replacement, Remove the battery: 9 단계, 이미지 3/3
    • Lift the battery straight out of its recess and remove it.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
129,330 평판
안내서 600개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 한 개
Thanks Alex, easy to follow
John Carmichael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 31
30일 전: 112
전체 시간: 2,909
