주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell XPS 15 9530 Memory Module Replacement
필요한 것
    1. Dell XPS 15 9530 Memory Module Replacement, Unscrewing the Base-Cover Assembly: 1 단계, 이미지 1개 중 1개
      • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
      • Don't forget to unscrew the two screws hidden under the system badge!
      댓글 쓰기
    2. Dell XPS 15 9530 Memory Module Replacement, Prying Off the Base-Cover Assembly: 2 단계, 이미지 1개 중 1개
      • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
      댓글 쓰기
    1. Dell XPS 15 9530 Memory Module Replacement, Remove Battery: 3 단계, 이미지 1개 중 1개
      • Remove the screws that secure the battery to the palm-rest assembly.
      • Disconnect the battery cable from the system board.
      • Lift the battery off the palm-rest assembly.
      • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
      댓글 쓰기
    1. Dell XPS 15 9530 Memory Module Replacement, Remove Memory: 4 단계, 이미지 1개 중 1개
      • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
      • Remove the memory module from the memory-module connector.
      댓글 쓰기
    2. Dell XPS 15 9530 Memory Module Replacement, Add New Memory Module: 5 단계, 이미지 1개 중 1개
      • Align the notch on the New memory module with the tab on the memory-module connector.
      • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
      • NOTE: If you do not hear the click, remove the memory module and reinstall it.
      댓글 쓰기
결론
To reassemble your device, put the battery back in and reaffix the base-cover assembly to the system.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
46,158 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 8,882개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 39
전체 시간: 1,637
