주요 콘텐츠로 건너뛰기
Dell XPS 15 9560 Battery Replacement
필요한 것
  1. Dell XPS 15 9560 Battery  Replacement, Back Panel: 1 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Battery  Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Battery  Replacement: 3 단계, 이미지 1/1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Battery  Replacement, Battery: 4 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Battery  Replacement: 5 단계, 이미지 1/1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Battery  Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 8명이 해당 안내서를 완성하였습니다.
Jada Houser
회원 가입일: 09/28/21
790 평판
안내서 7개 작성하였습니다
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G5
4 회원들
안내서 15개 작성하였습니다
댓글 한 개
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 76
30일 전: 297
전체 시간: 9,153
