주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell XPS 18 Touch Control Board Replacement
필요한 것
    1. Dell XPS 18 Touch Control Board Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Turn the device on its screen.
      • Remove the ten 4mm screws using a T8 Torx screwdriver.
      댓글 쓰기
    2. Dell XPS 18 Touch Control Board Replacement: 2 단계, 이미지 1개 중 1개
      • Gently flip out support feet located near the bottom of device.
      댓글 쓰기
    3. Dell XPS 18 Touch Control Board Replacement: 3 단계, 이미지 1개 중 1개
      • Gently lift the back cover off the device. The back cover should come off easily.
      댓글 쓰기
    1. Dell XPS 18 Touch Control Board Replacement, Internal Cover: 4 단계, 이미지 1개 중 1개
      • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
      댓글 쓰기
    2. Dell XPS 18 Touch Control Board Replacement: 5 단계, 이미지 2개 중 1개 Dell XPS 18 Touch Control Board Replacement: 5 단계, 이미지 2개 중 2개
      • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
      댓글 쓰기
    3. Dell XPS 18 Touch Control Board Replacement: 6 단계, 이미지 2개 중 1개 Dell XPS 18 Touch Control Board Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
      • Remove the internal cover.
      댓글 쓰기
    1. Dell XPS 18 Touch Control Board Replacement, Touch Control Board: 7 단계, 이미지 2개 중 1개 Dell XPS 18 Touch Control Board Replacement, Touch Control Board: 7 단계, 이미지 2개 중 2개
      • Disconnect the black camera cable and pull it back to prevent future hassle.
      댓글 쓰기
    2. Dell XPS 18 Touch Control Board Replacement: 8 단계, 이미지 2개 중 1개 Dell XPS 18 Touch Control Board Replacement: 8 단계, 이미지 2개 중 2개
      • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
      • Disconnect the silver and blue touch control board cable.
      댓글 쓰기
    3. Dell XPS 18 Touch Control Board Replacement: 9 단계, 이미지 2개 중 1개 Dell XPS 18 Touch Control Board Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
      • Remove the touch control board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Austin Weir
회원 가입일: 01/31/15
1,308 평판
안내서 8개를 작성함
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G29
4 회원들
안내서 16개를 작성함
2가이드 댓글
It worked perfectly. Thank you.
Kenneth Macdonald - 답글 공유
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
Евгений Громов - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 34
전체 시간: 2,318
