주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell XPS 720 H2C Sound Card Replacement
    1. Dell XPS 720 H2C Sound Card Replacement, Removing Dell XPS 720 H2C Cover Panel: 1 단계, 이미지 2개 중 1개 Dell XPS 720 H2C Sound Card Replacement, Removing Dell XPS 720 H2C Cover Panel: 1 단계, 이미지 2개 중 2개
      • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
      댓글 쓰기
    1. Dell XPS 720 H2C Sound Card Replacement, Sound Card: 2 단계, 이미지 2개 중 1개 Dell XPS 720 H2C Sound Card Replacement, Sound Card: 2 단계, 이미지 2개 중 2개
      • Before handling the inside of the computer, ensure that all wires are disconnected from the audio ports along the back panel.
      • The sound card is located towards the bottom of the computer, near the righthand side (see red outline).
      댓글 쓰기
    2. Dell XPS 720 H2C Sound Card Replacement: 3 단계, 이미지 3개 중 1개 Dell XPS 720 H2C Sound Card Replacement: 3 단계, 이미지 3개 중 2개 Dell XPS 720 H2C Sound Card Replacement: 3 단계, 이미지 3개 중 3개
      • To remove the support below the processor: press down on the latch at the top of the support, then pull the support outwards, towards yourself.
      댓글 쓰기
    3. Dell XPS 720 H2C Sound Card Replacement: 4 단계, 이미지 1개 중 1개
      • To unplug the wire that connects the sound card to the motherboard: grasp the wire tightly and pull it outwards, towards yourself.
      • The wire may appear to be stuck. Keep increasing your pulling force until the wire unplugs. It will not break.
      댓글 쓰기
    4. Dell XPS 720 H2C Sound Card Replacement: 5 단계, 이미지 1개 중 1개
      • To release the sound card from the motherboard casing: find the blue tab that is the third from the bottom (fifth from the top), and press down and to the right on the tab.
      댓글 쓰기
    5. Dell XPS 720 H2C Sound Card Replacement: 6 단계, 이미지 2개 중 1개 Dell XPS 720 H2C Sound Card Replacement: 6 단계, 이미지 2개 중 2개
      • To remove the sound card from the motherboard: gently grasp the sound card and pull directly outward, towards yourself.
      • Again, this may appear to be stuck in place. Slightly increase your pulling force until the card releases from the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
G B
회원 가입일: 04/17/13
67 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 31
전체 시간: 1,924
