주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Depth Sensor Node Streambed Installation Procedure
필요한 것
    1. Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: 1 단계, 이미지 3개 중 1개 Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: 1 단계, 이미지 3개 중 2개 Depth Sensor Node Streambed Installation Procedure, Preparing and setting first strut channel: 1 단계, 이미지 3개 중 3개
      • Clear large rocks from the streambed to make it easier to install the strut channel.
      • Place cleared rocks downstream so they do not damage the node during a storm.
      • Set 5 ft steel strut channel into place.
      • Ensure the open side of the strut channel faces south so that the solar panel receives maximum sunlight! Addtionally, be careful not to deform the steel strut channel too much. A bit of deformation is okay.
      • Use the post pounder to drive the strut channel 3 ft into the stream bed.
      댓글 쓰기
    2. Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: 2 단계, 이미지 3개 중 1개 Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: 2 단계, 이미지 3개 중 2개 Depth Sensor Node Streambed Installation Procedure, Attaching strut channel connector: 2 단계, 이미지 3개 중 3개
      • Place two spring strut channel nuts into the strut channel and then place the strut channel connector.
      • Two of the strut channel connector holes should be above the strut channel for connecting the top strut channel.
      • Insert two washers and screws into the nuts.
      댓글 쓰기
    3. Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: 3 단계, 이미지 3개 중 1개 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: 3 단계, 이미지 3개 중 2개 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel: 3 단계, 이미지 3개 중 3개
      • This is what the attached strut channel connector looks like from above.
      • Place two additional spring strut channel nuts into the aluminum strut channel to be attached.
      • Insert the last two washers and screws into the nuts.
      • Use an impact driver to secure the screws into place. The impact driver should have a 3/4 '' Socket connected via a socket adapter.
      • Socket Adapter
      • This is what the extended strut channel looks like.
      댓글 쓰기
    4. Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: 4 단계, 이미지 3개 중 1개 Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: 4 단계, 이미지 3개 중 2개 Depth Sensor Node Streambed Installation Procedure, Attaching the  strut channel arm: 4 단계, 이미지 3개 중 3개
      • Line up a 1 ft strut channel with a u-bracket to the vertical strut channel.
      • Put two spring strut channel nuts into the vertical strut channel. Insert two washers and screws into the u-bracket to hold the strut channel arm.
      • Use the impact driver to tighten the screws.
      • This is a what the final node holding structure looks like.
      댓글 쓰기
    5. Depth Sensor Node Streambed Installation Procedure, Attaching the node: 5 단계, 이미지 3개 중 1개 Depth Sensor Node Streambed Installation Procedure, Attaching the node: 5 단계, 이미지 3개 중 2개 Depth Sensor Node Streambed Installation Procedure, Attaching the node: 5 단계, 이미지 3개 중 3개
      • Place two screws into the node enclosure with the 5/16'' washer and strut channel nuts on the backside.
      • You can remove the strut channel nut spring to make installation easier.
      • Slide the node into the strut channel arm.
      • The washer should be on the outside of the strut channel and the strut channel nut should be on the inside.
      • Tighten the screws with a 3/8 inch wrench.
      댓글 쓰기
    6. Depth Sensor Node Streambed Installation Procedure, Attaching the lock: 6 단계, 이미지 1개 중 1개
      • Create a 4 number lock combination.
      • Projects have set lock combinations. Ask the lab for guidance.
      댓글 쓰기
    7. Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: 7 단계, 이미지 3개 중 1개 Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: 7 단계, 이미지 3개 중 2개 Depth Sensor Node Streambed Installation Procedure, Measuring starting depth: 7 단계, 이미지 3개 중 3개
      • Using a tape measure, measure the length from the bottom of the ultrasonic depth sensor to the water surface.
      • Measure the length from the bottom of the ultrasonic depth sensor to the bottom of the stream bed.
      댓글 쓰기
    8. Depth Sensor Node Streambed Installation Procedure, Trim foliage that may block solar panel: 8 단계, 이미지 2개 중 1개 Depth Sensor Node Streambed Installation Procedure, Trim foliage that may block solar panel: 8 단계, 이미지 2개 중 2개
      • If foliage may block the solar panel from charging, trim some branches.
      • This is a completely installed stream bed depth sensor node!
      댓글 쓰기
    9. Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel arm: 9 단계, 이미지 2개 중 1개 Depth Sensor Node Streambed Installation Procedure, Attaching additional strut channel arm: 9 단계, 이미지 2개 중 2개
      • Sometimes two strut channel arms are preferred over one.
      • Attach a second 1 ft strut channel arm using the same hardware as the first strut channel arm.
      • Use the node enclosure to determine how far apart the two arms need to be.
      • Tighten the screws with the impact drill.
      댓글 쓰기
    10. Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: 10 단계, 이미지 3개 중 1개 Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: 10 단계, 이미지 3개 중 2개 Depth Sensor Node Streambed Installation Procedure, Attaching node to two arms: 10 단계, 이미지 3개 중 3개
      • Place four screws into the node enclosure with the washer and strut channel nuts on the backside.
      • This is what the node looks like attached to two strut channel arms.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brooke Mason
회원 가입일: 05/29/19
2,958 평판
안내서 17개를 작성함
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 74개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 27
전체 시간: 682
