주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Desktop PC CD Drive Replacement
필요한 것
  1. Desktop PC CD Drive Replacement, Optical Drive: 1 단계, 이미지 1개 중 1개
    • Find a large table or flat non-carpeted space to work.
    • Unplug all external cables, including the power cable, from your computer.
    • Touch a metal piece of your computer case in order to release any built up static electricity. Make sure to do this frequently throughout the replacement.
    댓글 쓰기
  2. Desktop PC CD Drive Replacement: 2 단계, 이미지 2개 중 1개 Desktop PC CD Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Find the screws that are holding together the side of your computer case and unscrew them.
    • Slide the side panel of the computer case toward the back of the case and remove it.
    • Repeat for second panel.
    댓글 쓰기
  3. Desktop PC CD Drive Replacement: 3 단계, 이미지 3개 중 1개 Desktop PC CD Drive Replacement: 3 단계, 이미지 3개 중 2개 Desktop PC CD Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Depending on the case, It may be necessary to remove the top panel in order to get to the CD drive. If you can access the drive without removing the top, skip this step.
    • On the back of the computer, unscrew the screws connecting the top panel to the case.
    • Inside the computer, Unscrew the screws connecting the top panel to the case.
    • Slide the top panel backward and lift it off the case.
    댓글 쓰기
  4. Desktop PC CD Drive Replacement: 4 단계, 이미지 3개 중 1개 Desktop PC CD Drive Replacement: 4 단계, 이미지 3개 중 2개 Desktop PC CD Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Locate the CD drive within the computer case.
    댓글 쓰기
  5. Desktop PC CD Drive Replacement: 5 단계, 이미지 3개 중 1개 Desktop PC CD Drive Replacement: 5 단계, 이미지 3개 중 2개 Desktop PC CD Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the cables attached to the back of the CD drive.
    • Remove the cables. In order to do this gently but firmly grasp the cables and pull backwards.
    • I recommend marking the cords you unplug with a piece of tape so you can easily find them again later.
    • If the cables are unreachable, you may need to do the next two steps before this one.
    댓글 쓰기
  6. Desktop PC CD Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Locate and unscrew the screws holding the CD drive to the case.
    댓글 쓰기
  7. Desktop PC CD Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Slide CD drive out of the front of the case.
    댓글 쓰기
  8. Desktop PC CD Drive Replacement: 8 단계, 이미지 3개 중 1개 Desktop PC CD Drive Replacement: 8 단계, 이미지 3개 중 2개 Desktop PC CD Drive Replacement: 8 단계, 이미지 3개 중 3개
    • Get your new CD drive.
    • Pull the taped cables through the opening for the CD drive.
    • Remove the tape from the cables.
    • Plug the cables into the new CD drive.
    • Slide the new CD drive back into the front of the case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 29명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mitchell Zehr
회원 가입일: 02/24/15
954 평판
안내서 1개를 작성함
Cal Poly, Team 23-2, Green Winter 2015 Cal Poly, Team 23-2, Green Winter 2015 회원
CPSU-GREEN-W15S23G2
4 회원들
안내서 18개를 작성함
2가이드 댓글
موقع سي جدا جدا لا يمكن الاعتماد علية
Hayder77 Ail lbdlbd - 답글 공유
موقع سي لا يعتمد علية
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 34
지난 30일: 102
전체 시간: 9,820
