주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Desktop PC Front Fan Replacement
필요한 것
  1. Desktop PC Front Fan Replacement, Left Panel: 1 단계, 이미지 1개 중 1개
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    댓글 쓰기
  2. Desktop PC Front Fan Replacement: 2 단계, 이미지 2개 중 1개 Desktop PC Front Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    댓글 쓰기
  3. Desktop PC Front Fan Replacement, Front Fan: 3 단계, 이미지 2개 중 1개 Desktop PC Front Fan Replacement, Front Fan: 3 단계, 이미지 2개 중 2개
    • Push to unlatch three grey connectors on the front panel.
    댓글 쓰기
  4. Desktop PC Front Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the front panel from the computer face.
    댓글 쓰기
  5. Desktop PC Front Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Remove four Phillips #2 head, 5mm screws holding in the fan.
    댓글 쓰기
  6. Desktop PC Front Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Slide the fan out from the side of the casing.
    댓글 쓰기
  7. Desktop PC Front Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the power cable from the fan.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 39명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
David Lennon
회원 가입일: 04/14/15
10,198 평판
안내서 10개를 작성함
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 회원
CPSU-MANESS-S15S4G5
4 회원들
안내서 45개를 작성함
2가이드 댓글
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - 답글 공유
I did this with my pc and I was able to restore and add a new fan because the other one wouldn’t work because the wire was snapped so I decided to replace it and this guide helped me
TechNinja - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 25
지난 7일: 88
지난 30일: 197
전체 시간: 31,509
