주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Desktop PC Hard Drive Replacement
필요한 것
  1. Desktop PC Hard Drive Replacement, Left Panel: 1 단계, 이미지 1개 중 1개
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    댓글 쓰기
  2. Desktop PC Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Desktop PC Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    댓글 쓰기
  3. Desktop PC Hard Drive Replacement, Right Panel: 3 단계, 이미지 1개 중 1개
    • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
    댓글 쓰기
  4. Desktop PC Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Desktop PC Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    댓글 쓰기
  5. Desktop PC Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1개 중 1개
    • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
    댓글 쓰기
  6. Desktop PC Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
    댓글 쓰기
  7. Desktop PC Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Slide the hard drive out from the metal casing.
    댓글 쓰기
  8. Desktop PC Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the cables from the back of the hard drive.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 64명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Rubin Girling
회원 가입일: 04/14/15
776 평판
안내서 1개를 작성함
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 회원
CPSU-MANESS-S15S4G5
4 회원들
안내서 49개를 작성함
2가이드 댓글
Footnote: the processing of removing a drive from your system may vary slightly depending on the manufacturer of your system, or if you built it yourself; the manufacturer of the case.
Jack G - 답글 공유
Pour remonter l'installation,
-remonter le disque dur faite le glisser dans la cage métallique
- fixer le disque dur avec les vis retirées
-fixer les câbles à l'arrière du disque( câble d'alimentation et nappe de données)
-mettre les panneaux dans l'ordre du retrait
- procéder à l'installation du système d'exploitation...
Rufin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 170
전체 시간: 12,451
