주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Desktop PC Left Panel Replacement
필요한 것
  1. Desktop PC Left Panel Replacement, Left Panel: 1 단계, 이미지 1개 중 1개
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    댓글 쓰기
  2. Desktop PC Left Panel Replacement: 2 단계, 이미지 2개 중 1개 Desktop PC Left Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 24명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
David Lennon
회원 가입일: 04/14/15
10,198 평판
안내서 10개를 작성함
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 회원
CPSU-MANESS-S15S4G5
4 회원들
안내서 45개를 작성함
3가이드 댓글
What is the name of the case used in this tutorial?
Nicolas Hunter - 답글 공유
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - 답글 공유
I have this same case in black and want to know what model it is.
numanair - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 17
지난 30일: 100
전체 시간: 9,748
