주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Desktop PC RAM Replacement
필요한 것
  1. Desktop PC RAM Replacement, Left Panel: 1 단계, 이미지 1개 중 1개
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    댓글 쓰기
  2. Desktop PC RAM Replacement: 2 단계, 이미지 2개 중 1개 Desktop PC RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
    댓글 쓰기
  3. Desktop PC RAM Replacement, RAM: 3 단계, 이미지 1개 중 1개
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
    댓글 쓰기
  4. Desktop PC RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
    댓글 쓰기
결론
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
취소: 해당 안내서를 완성하지 않았습니다.
다른 53명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
David Lennon
회원 가입일: 04/14/15
10,198 평판
안내서 10개를 작성함
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 회원
CPSU-MANESS-S15S4G5
4 회원들
안내서 45개를 작성함
4가이드 댓글
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - 답글 공유
very interesting
maciekErd123 - 답글 공유
how to determine the speed
benzy aceware - 답글 공유
how can i differentiate between types of rams
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 89
전체 시간: 8,919
