주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DigiLand DL8006 LCD Screen Replacement
필요한 것
  1. DigiLand DL8006 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 DigiLand DL8006 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 DigiLand DL8006 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • Place the device laying down on its front with the back facing upwards.
    • Use the opening tool to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
    • After removing the panel, remove the silver/metallic tape on the lower end of the tablet.
    댓글 쓰기
  2. DigiLand DL8006 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 DigiLand DL8006 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 DigiLand DL8006 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the red and black cord connecting the motherboard and the bottom end of the tablet.
    • Remove the ribbon cable running over the battery. This can be done by prying the locking tab of the ZIF connector, up and then pulling the cable from the connector.
    댓글 쓰기
  3. DigiLand DL8006 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 DigiLand DL8006 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the red and black cord that connects the motherboard and the camera. This cord is found on the upper end of the device.
    • Remove the red and blue cord connecting the battery to the motherboard.
    • Remove the tape connecting the back of the LED screen and the motherboard.
    댓글 쓰기
  4. DigiLand DL8006 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 DigiLand DL8006 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the cable connecting the motherboard to the left side of the device.
    • Remove both cables connecting the camera to the motherboard.
    댓글 쓰기
  5. DigiLand DL8006 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 DigiLand DL8006 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 DigiLand DL8006 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the screw on the left corner of the motherboard with a Phillips #0 screwdriver.
    • Remove the screw under the ribbon cable with a Phillips #0 screwdriver.
    • Remove the screw on the top of the motherboard with a Phillips #0 screwdriver.
    댓글 쓰기
  6. DigiLand DL8006 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Gently lift the motherboard out of the device and place it aside.
    댓글 쓰기
  7. DigiLand DL8006 LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 DigiLand DL8006 LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 DigiLand DL8006 LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 3 screws anchoring down the LED screen down with a Phillips #0 screwdriver. These screws can be found in the top right, bottom right, and bottom left of the device.
    댓글 쓰기
  8. DigiLand DL8006 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Using an opening tool, gently pry the LCD screen and glass screen apart.
    • Remove the battery by using the opening tool, or by removing the tape on the upper and lower end of the battery. From here, a new LCD screen can be inserted.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Landon Choi
회원 가입일: 10/30/19
379 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 611
