주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DigiTech RP70 Footswitch Replacement
필요한 것
    1. DigiTech RP70  Footswitch Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 DigiTech RP70  Footswitch Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
      • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
      • Remove the four 8mm Phillips #0 screws located on the back panel.
      댓글 쓰기
    2. DigiTech RP70  Footswitch Replacement: 2 단계, 이미지 2개 중 1개 DigiTech RP70  Footswitch Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the back panel to expose the motherboard.
      댓글 쓰기
    3. DigiTech RP70  Footswitch Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
      댓글 쓰기
    4. DigiTech RP70  Footswitch Replacement: 4 단계, 이미지 1개 중 1개
      • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
      댓글 쓰기
    1. DigiTech RP70  Footswitch Replacement, Footswitches: 5 단계, 이미지 3개 중 1개 DigiTech RP70  Footswitch Replacement, Footswitches: 5 단계, 이미지 3개 중 2개 DigiTech RP70  Footswitch Replacement, Footswitches: 5 단계, 이미지 3개 중 3개
      • Pull firmly on the binder clips that are holding the footswitches in place to remove them.
      • To get the binder clips back in place, you will need to attach handles from another binder clip to hold them open.
      댓글 쓰기
    2. DigiTech RP70  Footswitch Replacement: 6 단계, 이미지 1개 중 1개
      • Pull the footswitch down and upwards to remove it from the casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elijah Smith
회원 가입일: 09/10/18
738 평판
안내서 6개를 작성함
1가이드 댓글
So what is the fix? Replacing both foot switches with new ones? Or removing them and reinstalling them will fix the problem of them not working at all? What’s Step 7? If you stop after completing Step 6 you now just have a casing without foot switches. What will fix the problem of them not working qt all after removing the foot switches?
Carl - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 27
전체 시간: 1,435
