주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Direct-Drive Cleaner Head Brush Bar Replacement
필요한 것
    1. Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: 1 단계, 이미지 2개 중 1개 Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: 1 단계, 이미지 2개 중 2개
      • First, make sure the device is unplugged and detached from the wand
      • Use a quarter to unlock the fastener marked by padlocks, turning it counter clockwise
      • Padlocks
      댓글 쓰기
    2. Direct-Drive Cleaner Head Brush Bar Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the brush bar away from the cleaner head
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Saba G Arefaine
회원 가입일: 10/18/17
272 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G5, Rose Fall 2017 UW Tacoma, Team S1-G5, Rose Fall 2017 회원
UWT-ROSE-F17S1G5
4 회원들
안내서 32개를 작성함
3가이드 댓글
While a clogged head was not the reason my Dyson V8 was stuttering, logic prompted me to check the big tube for an obstruction. My Dyson had a hairball as a result of picking up after my cat. Thank you!
John McCormick - 답글 공유
My daughters Dyson V8 head is not powering the tube and rotating head. I have a Dyson V10 animal which I can attach to the V8 tube and rotating head and operates, so the problem is in the power head. I have cleaned the contacts and don’t know what else to do. Any suggestions?
Tom Murphy - 답글 공유
I’ve cleaned it but it’s still not working. Any other suggestions?
Gem - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 118
전체 시간: 38,913
